It is currently Tue Aug 05, 2025 8:08 am
 Post subject: Performax 22-44 Pro
PostPosted: Tue Sep 22, 2015 10:22 pm
Does anyone have experience with one of these? It's the older 1.5hp. I'm looking at one but the height adjustment is real hard to turn. We shot some wd40 at it but didn't really help. Grease?
Thoughts on them in general? I currently use a 16" 1hp Ryobi wich does good, just looking to upgrade.
Thanks!
 Post subject: Re: Performax 22-44 Pro
PostPosted: Tue Sep 22, 2015 11:08 pm
First name: paul
Last Name: groneck
City: federal way
State: wa
Zip/Postal Code: 98003
You should check out equipment sales and surplus in auburn. They sell refurbished jet and powermatic equipment. I got a 22" jet that was basically new for about the same price.
PostPosted: Sun Sep 27, 2015 2:23 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I also have the 16" Ryobi, which I bought new. It was very hard to turn the height adjustment when I got it. The cure was to loosen the adjusting screws on the ways. It is a delicate adjustment....too loose and the cutter head will wiggle up and down when sanding.
PostPosted: Sun Sep 27, 2015 5:16 am
State: Tennessee
pat macaluso wrote:
http://seattle.craigslist.org/est/tls/5231070193.html
Thanks!
Mine works very well, adjustment is the key, I really like the poly belt.
PostPosted: Mon Sep 28, 2015 2:23 pm
hmmm.....Looks like they sell for hardly under list
I'm familiar with that, but its the Performax 22-44 Pro that I'm asking.
This one has a sandbelt. What do you mean by adjustment? It has various sets of gears and bushings and somewhere along it's difficult to turn the height adjustment. I suspect the gears and not the bushings. They look ok but maybe wearing out? Need some special grease?
PostPosted: Mon Sep 28, 2015 2:41 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Pat, on all my machines that adjust with a crank and threaded way, the threads need to cleaned periodically. This problem is worsened by milling pitchy or oily woods. For stubborn build up on the threads, oven cleaner works great.
PostPosted: Mon Sep 28, 2015 10:09 pm
First name: paul
Last Name: groneck
City: federal way
State: wa
Looks like list on the jet 22-44 is over $2k on Amazon
PostPosted: Thu Oct 01, 2015 1:10 am
Last Name: Arnold
City: Newport
The principle for adjustment is the same.
The cutterhead slides up and down on ways. There are bolts with locking nuts that adjust how tight the sliding mechanism is. Loosen the locking nuts, turn the bolts, and retighten the nuts.
If this adjustment is too tight, no amount of cleaning or lubrication will help.
PostPosted: Thu Oct 01, 2015 9:48 am
Thanks John, but I think you are referring to the regular 22-44. The 22-44 Pro is totally different. It has two bevel gears and the table moves up and down instead of the drum.Image
Users browsing this forum: Cal Maier, jfrench and 14 guests
