It is currently Mon Jul 28, 2025 8:16 pm
PostPosted: Thu Jan 21, 2016 9:59 pm
First name: D
Last Name: S
After cutting the slots, I re-measured. One was off by about 1/32".
The board is Ebony, what's the best way to fill it?
I'm thinking CA and dust, but not sure. The new slot will be right on the edge of the fill.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Jan 21, 2016 10:03 pm
Last Name: Kincheloe
Recent thread on this: http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=46945
PostPosted: Fri Jan 22, 2016 5:45 am
State: Tennessee
Dan
Properly fitted slice of ebony and you'll never find it.
PostPosted: Fri Jan 22, 2016 9:08 am
First name: D
Last Name: S
Thanks!
I just remembered I have some Ebony veneer.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jan 22, 2016 10:14 am
Yep
PostPosted: Fri Jan 22, 2016 1:32 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Is he FB going to be bound, Dan? If it is, the fret and binding should hide the repair from the top and the sides of thr FB.
Alex
PostPosted: Fri Jan 22, 2016 1:57 pm
First name: D
Last Name: S
Alex
Yes, It will be bound.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jan 22, 2016 3:39 pm
First name: Jeff
Last Name: Duncan
City: Concord
State: Ma.
Zip/Postal Code: 01742
If you haven't cut the fretboard to length yet you can fix the same way I did mine, (post linked above). I used a sharp razor saw and a block with a shallow angle, (maybe 3-5 degrees off 90), as a guide to slice off a small wedge shaped fill from the end of the finger board blank. Apply a small amount of yellow glue to the edges and gently tap down into place.
Not the easiest fix but works well and makes the fix nearly invisible since it's the same wood with the grain in the same direction. Of course if you frets and binding are large enough it may not be a concern anyway!
good luck,
Jeff
PostPosted: Fri Jan 22, 2016 6:21 pm
"One was off by about 1/32"."
Which fret was it? If it one of the frets near the peghead it might be less critical than one further down the board. If I'm thinking right at the first fret it would only throw things off by about 2 cents. Further down it would be a bit more.
PostPosted: Fri Jan 22, 2016 7:07 pm
First name: D
Last Name: S
It is fret 6.
The board is Ebony, so I think appearance will be fine.
I was worried about cutting a new slot next to the repair.
I think if I use a veneer or cutoff piece rather than dust I'll be ok.
wah
Wah-wah-wah-wah
Wah
