It is currently Sat Aug 16, 2025 11:50 pm
PostPosted: Sat Apr 16, 2016 4:05 pm
Getting ready to try my hand at bending and installing LMI herringbone purfling for the first time. I'm not ashamed to admit that it is a scary thought. The idea of bending something like that on edge seems like a prescription for disaster! Unlike binding where, if things go wrong one can simply make some more, I have to get it right the first time. What says the collective wisdom out there? Any suggestions would be gratefully accepted.
PostPosted: Sat Apr 16, 2016 4:44 pm
State: Tennessee
Have you tried a dry run around your channel? I've used herringbone from LMI, Stew Mac, and Bluescreek and it bends easily
PostPosted: Sat Apr 16, 2016 4:58 pm
Here's a procedure that works well:
Ken Cierp
PostPosted: Sat Apr 16, 2016 9:44 pm
Similar to the above. Works well.
http://kennedyguitars.com/bending-herringbone.html
PostPosted: Sun Apr 17, 2016 8:38 am
First name: Tom
Last Name: West
State: Nova Scotia
Pete: Lots of different opinions out there re: herringbone purfling. Some folks says they don't pre-bend but that has always made me pucker a bit on my back side for fear of breakage during installation. Others say they can't wet herringbone because it falls apart. I've used LMI's both the fine and course grain and run it under hot water a while before bending and have not had any problems with delamination. I use a combination of Ken's and Terence's methods.
A form like Terence and brads like Ken with a thin pine caul to help prevent any marking from the brads. A hair dryer or heat gun also helps if you are having trouble fitting to the form. Good luck and take care.
Tom
PostPosted: Sun Apr 17, 2016 3:39 pm
make it easy
if you are bending the side just tape it to it. If you use the bender alone put some binding between the herringbone and tape it.
if your doing a dred run it under hot water and tape it to the guitar let set over night. Don't over think it. it isn't that hard.
PostPosted: Mon Apr 18, 2016 12:20 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I use a clothes iron to soften the purfling on the bench. Then fit it right onto the guitar body with lots of tape. It doesn't take much heat to make it bend so be careful
