It is currently Sat May 23, 2026 5:36 am
 Post subject: Superglue Yellowing
PostPosted: Wed Jun 22, 2016 12:38 pm
First name: Gary
Last Name: Leddington
Hi Folks.
After gluing in a rosette a couple of weeks back its seems that some areas a round the inlays have yellowed a bit, i presume from the superglue i used.
I used cheap glue, i guess this is the main problem, but does anyone know any fixes for this other than the obvious of using better quality glue?
G.
www.leddingtonguitars.com
 Post subject: Re: Superglue Yellowing
PostPosted: Wed Jun 22, 2016 12:58 pm
First name: Brad
Last Name: Combs
Is it the rosette or the soundboard that is discolored? Did you seal the rosette channel before gluing it in?
PostPosted: Wed Jun 22, 2016 1:00 pm
Gary,
Spruce must be sealed with shellac prior to the application of CA adhesives. I've also seen the same yellow staining on soft maple and similar problems with cedar so I seal all light colored woods before applying super glue.
PostPosted: Wed Jun 22, 2016 1:33 pm
I think they've got it. Sounds like superglue wicked into the end grain of the unsealed rosette channel. Get yourself a bag of dewaxed shellac flake and make shellac as required...
PostPosted: Wed Jun 22, 2016 2:32 pm
First name: Gary
Well thanks for the replies guys.. and duly noted regarding the shellac.
PostPosted: Wed Jun 22, 2016 3:42 pm
I used some cheap Chinese super glue from Walmart that yellowed after a few weeks. [headinwall] It didn't work out to be a good way to cut costs. The glue penetrated deep into the fibers of the wood and could not be sanded out. I wound up doing a sunburst finish to hide the stains.
You might be able tostain the top a matching yellow and do a tobacco sunburst.
PostPosted: Wed Jun 22, 2016 6:17 pm
I do not use CA on spruce
Duco for all my rosettes. The first few guitars I used CA all yellowed .
PostPosted: Wed Jun 22, 2016 6:26 pm
I can actually detect discoloration on a CA seam in BRW.
PostPosted: Wed Jun 22, 2016 9:59 pm
Like the Taylor factory we use clear nitro lacquer to seal the rosette and binding channels if CA is going to be used for assembly.
Ken Cierp
Users browsing this forum: No registered users and 337 guests
