It is currently Wed Jul 30, 2025 9:16 pm
PostPosted: Wed Sep 14, 2016 11:08 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have a friend who purchased one of these on ebay and though I have not yet looked at it a local setup guy says it needs a neck reset. Does anyone know what the neck joint is on this guitar, I am thinking like a less paul or other Gibson electrics but I have not had the guitar on my bench yet.
Fred
Fred Tellier
PostPosted: Wed Sep 14, 2016 11:14 am
I've always like those guitars. I have no idea about the joint except that it is a set neck but I'm surprised a solid body nylon string guitar would need a neck reset. has it been to hell and back or perhaps had some medium acoustic strings on it?
PostPosted: Wed Sep 14, 2016 11:32 am
First name: Fred
Last Name: Tellier
City: Windsor
I have yet to see the guitar but trying to gather info for the owner so I can give him a good answer on what it needs. I have a feeling that it is not that bad, he is a very fussy player.
Fred
Fred Tellier
PostPosted: Wed Sep 14, 2016 3:09 pm
Like many Gibsons, Fred - you'll probably have to yank the fingerboard to look at the neck joint.
I am also skeptical about it needing a neck reset.
The ones I've worked on tend to have very high saddles, and a little off the bottom will fix it.
PostPosted: Fri Sep 16, 2016 7:16 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
A regular of mine plays the steel string version of that guitar.....if it is built the same as that a neck set doesn't look like any fun. Not quite MK3 bad but right up there. The body is a semi hollow stacked nightmare of lots of spruce....
Brian
PostPosted: Fri Sep 16, 2016 9:10 am
City: Lawrence
Zip/Postal Code: 66047
MK3 ?
