It is currently Sat Jun 13, 2026 7:15 am
 Post subject: Transtint question.
PostPosted: Wed Jan 04, 2017 4:13 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
I want to use Transtint to achieve a wine\ cranberry\ burgundy stain. What colors do you mix to get that Gibson Wine color?
 Post subject: Re: Transtint question.
PostPosted: Wed Jan 04, 2017 9:56 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have done a number of partial or full refinishes on wine red Gibsons, including a nice Wes Montgomery L-5 that was shedding it's top coats due to sealer/topcoat issues. Neck replacements or refinishes are more of a challenge, although we have been able to achieve close matches between aged bodies and fresh neck finishes with the following approach:
- After careful finish removal from several Gibsons, we believe that a medium brown toner coat (dye-in-lacquer) - similar to Brown Mahogany Transtint - is used to provide a uniform base color for the various wood combinations seen.
- This toner is applied over clear sealer, then a red toner coat (Cherry Red and Bordeaux Transtint at about 5:1 ratio seems to work well) is applied over the brown base coat, and after scraping the bindings, top-coated with clear gloss lacquer.
Hope this helps!
PostPosted: Sat Jan 07, 2017 4:03 am
Last Name: Howell
City: Atlanta
State: Ga
I got the burgundy color years ago by mixing transtint bright red and black because I had it. But the explanation above appears to be well worked out and might be a better fit to your case.
PostPosted: Sat Jan 07, 2017 10:24 am
First name: D
Last Name: S
Same here Bob.
I reckon because of the chemistry involved, mixing colors may not give an expected result.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Jun 12, 2018 5:14 pm
Hope this helps!
Hey, Woodie. When you spray a dark toner like that about how much dye are you putting in an ounce of lacquer? I always find it hard to strike a balance between too much and obscuring the figure and too little requiring too many coats to get the color where I want it. Thanks.
Users browsing this forum: jfrench and 33 guests
