It is currently Tue Jul 29, 2025 5:39 pm
PostPosted: Wed Mar 01, 2017 12:05 pm
First name: Raymond
Last Name: Morin
City: Pittsburgh
State: PA
Zip/Postal Code: 15224
This is a first for me. How would you guys approach removing a damaged bridge plate that was glued on with fish glue?
PostPosted: Fri Mar 03, 2017 8:09 am
Last Name: Farmer
City: Durango
State: CO
Closed instrument? Bridge on?
Does it really need removal? There are ways to fix string ball damage without removing the plate
If it's a top not on an instrument yet, I would just plane it down to the glue and scrape.
Is the center seem fish glue?
Fish glue should turn loose pretty easily w/ moisture. I've had great success with hide glued maple by sitting a moist sponge cut to the size of the plate with the instrument face down. I put a piece of plastic on top of the sponge so more of the moisture goes into the plate instead of evaporating out the other side. I don't let the sponge contact any surrounding braces. leave it all day and check every few hours to see if you can slide a thin spatula or feeler gauge into the glue line. I might take 8 hours or more. Thanks to John Hall of blues Creek for this method. If that's not enough, I break out the hot chunks of plate shaped aluminum screwed to a bridge clamp and the excitement begins.
These users thanked the author david farmer for the post (total 3): dpetrzelka (Fri Mar 03, 2017 10:37 am) • CraigG (Fri Mar 03, 2017 8:50 am) • Hesh (Fri Mar 03, 2017 8:36 am)
PostPosted: Fri Mar 03, 2017 10:22 am
First name: Raymond
Last Name: Morin
City: Pittsburgh
State: PA
Thanks David.
John was actually nice enough to share that technique with me on the phone yesterday, and it worked a treat! Sponge overnight, heat blanket this morning at 150 degrees, it pried off in about 2 minutes with no damage to the guitar whatsoever. Now I'm going to let everything dry out fully, scrape any residue and get a new plate in there. Big load off of my mind!
PostPosted: Fri Mar 03, 2017 1:16 pm
Last Name: Farmer
City: Durango
State: CO
Right on!
Users browsing this forum: guitarjtb and 15 guests
