It is currently Fri Apr 24, 2026 10:35 pm
 Post subject: bridge weight 40grams
PostPosted: Thu Mar 23, 2017 10:29 am
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
Is a bridge weigh of 40 grams ok. I have this bridge finished and can not get the weight down. I usually shoot for 35.
PostPosted: Thu Mar 23, 2017 10:40 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
How big is the guitar? That may be OK for a dred or jumbo, but I think it's a little too heavy.
It can be made to work, depending on the rest of the design. I typically use much lighter bridges (~25 grams), so it would be good to wait for someone that uses a heavier bridge. I believe Somogyi uses 35 grams for his bridges, so heavy bridges can work.
PostPosted: Thu Mar 23, 2017 10:55 am
Never made one as heavy (even from African Blackwood) as that so I can't say, what's it mde from? And a pic may bring suggestions to lighten it if you want to.
I typically shave a slope south of the saddle, to around 2.5mm at the rear after gluing it on.
PostPosted: Fri Mar 24, 2017 8:54 am
First name: Daniel
Last Name: Petrzelka
State: Washington
Have any of you opened up a cavity in the bottom of a bridge to lighten the weight?
Maintaining the full perimeter of the footprint, but just adding some pockets might bring the weight down, but still preserve a very functional gluing footprint.
I have never tried this myself, but I keep thinking about the Gibson mustache style bridges...
PostPosted: Mon Mar 27, 2017 10:59 am
I've thought about that, but worry about the surface area reduction for gluing strength. Although I've never considered the Gibson mustache bridge when trying to think through that.
PostPosted: Mon Mar 27, 2017 12:46 pm
Last Name: Beaver
City: Lake Forest
Depends. If it is a large top, with fairly lightl bracing and a light bridge plate, a heavy bridge might be just the ticket. I had a similar situation with an african blackwood bridge. It worked great. I'd have to check my records but I think it 39g
If yours is a OM or SJ or smaller sized guitar and is heavily braced it probably will hinder top response. But my experience is limited to one heavy bridge. I mostly use bois de rose for 27 to 32g bridges now.
Joe Beaver
Maker of Sawdust
Users browsing this forum: No registered users and 182 guests
