It is currently Thu May 14, 2026 11:48 am
PostPosted: Sat Apr 29, 2017 4:51 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I want to start laying up my own b/w/b purfling and would appreciate any info on where to buy the veneers. I've seen a lot on E-Bay but not sure about them. I prefer some that won't "run" or bleed into the spruce when French Polished.
PostPosted: Sat Apr 29, 2017 10:11 pm
City: Escondido
Zip/Postal Code: 92029
I've used this stuff, and never had runs with FP. I'm sure I'll say that and the next batch will run like Usain Bolt, but for now they have worked well. Ordered twice, about ten sheets of black/ ten of white each time.
http://www.dyed-veneer.com/dyed_veneers.aspx
PostPosted: Sun Apr 30, 2017 6:58 am
First name: Brad
Last Name: Combs
Maybe the fiber veneer from RC? They are a forum sponsor. I use the 0.020 thick when making binding that has purfling attached. Get a zero clearance fitting for your bandsaw and slice them up!
http://rctonewoods.com/RCT_Store/fiberv ... 3ivvtbaiu1
PostPosted: Sun Apr 30, 2017 7:28 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I get my holly , rosewood, black dyed castello , and other veneers from certainly wood veneer in aurora NY fast friendly efficient service . Good prices . bliss
PostPosted: Thu May 04, 2017 12:38 pm
LMII sells dyed veneers, in both .5 and .3mm thickness, including black.
I like to get maple veneer locally for the white. You can often find curly veneer, which, since it's generally flat cut, means that the curl shows most effectively on the edge grain that you'll be seeing in the layup. You can also sometimes find ~.8mm ( the old American standard thickness of 1/28") stock, which gives you more choices of line widths.
These users thanked the author Alan Carruth for the post: bcombs510 (Thu May 04, 2017 1:37 pm)
Users browsing this forum: No registered users and 78 guests
