It is currently Mon Sep 15, 2025 8:20 am
 Post subject: oil over shellac
PostPosted: Wed Oct 18, 2017 3:06 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Can any of the oil finishes be used over dewaxed shellac.
Mike McNerney
 Post subject: Re: oil over shellac
PostPosted: Wed Oct 18, 2017 3:58 pm
I have put TruOil over shellac. Worked just fine and still in good shape about 15 years later.
PostPosted: Wed Oct 18, 2017 6:17 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Me too, no problem yet.
B
PostPosted: Wed Oct 18, 2017 11:28 pm
First name: George
City: Seattle
I've used several different oil varnishes over a seal coat of dewaxed shellac without any problems whatsoever. In fact, the only issue I've had with any varnish was over rosewood that had not first been been sealed with shellac. It simply wouldn't dry until I scraped it off, sealed with shellac, and reapplied.
George :-)
These users thanked the author George L for the post: Pmaj7 (Thu Oct 19, 2017 11:20 am)
PostPosted: Thu Oct 19, 2017 8:05 am
Yup I think shellac is the universal sealer. I would guess that dewaxed, as you mentioned, is key though. I've been using an oil varnish for the past 3 years and always seal with shellac, so far so good.
PostPosted: Thu Oct 19, 2017 8:10 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
thanks to all I'm doing it.
Mike McNerney
PostPosted: Thu Oct 19, 2017 7:09 pm
Last Name: Cox
Depends on what kind of oil finish. Varnishes are probably OK so long as you dewax the shellac and make sure to lightly scuff it... Don't want the varnish to peel back off.
With plain oil finishes - I would not apply over shellac as they will just leave a sticky mess...
PostPosted: Thu Oct 19, 2017 7:34 pm
The term 'varnish' is so loosely used it can lead to all kinds of problems. I'm not sure even calling it an 'oil' varnish helps. The best answer to all these kinds of questions is... make test panels. Of course sometimes these things don't appear as problems for some time.
PostPosted: Thu Oct 19, 2017 7:50 pm
Last Name: Howell
City: Atlanta
State: Ga
Shellac is used as a sealer to reduce/control the amount of oil that is adsorbed. A wash coat of 1/2 lb cut will have a little effect. Remember Minwax stains are dilute linseed oil and pigment and a little dye.
At some point the oil will not soak in and must be wiped off
PostPosted: Fri Oct 20, 2017 2:29 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use a siamese red shellac that has some wax in it . Then finish with tru oil or cabinetmakers varnish or laquer. I am using med grade ca glue for finishing open pored woods before final finishing and after sealing with shellac, and experimenting with 2 part epoxy pore filler which I find dificult to master
PostPosted: Fri Oct 20, 2017 2:32 pm
First name: George
City: Seattle
FWIW, these are the specific "varnishes" I have used successfully over a seal coat of dewaxed shellac, all of which are holding up just fine after 10+ years:
Pratt & Lambert #38
Ace Hardware Great Finishes (solvent-based)
Tru-Oil
Yeah, when trying any material, process, or tool for the first time, testing on scrap is always a good idea.
George :-)
PostPosted: Sun Oct 22, 2017 8:30 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
"Shellac sticks to everything, and everything sticks to shellac"
I was taught this in the 70's by an old furniture repair guy. I have 40 year old furniture projects around the house with a couple of coats of padded de-waxed shellac, covered in everything from spar varnish (polishes beautifully), to alkyd varnish, to water based varnish, urethanes too, and have never had a failure.
Ed
These users thanked the author Ruby50 for the post: Pmaj7 (Sun Oct 22, 2017 11:07 am)
Users browsing this forum: doncaparker and 96 guests
