It is currently Mon Apr 27, 2026 8:40 pm
PostPosted: Fri Nov 10, 2017 4:20 pm
Is a 16 degree headstock angle too severe?
Now for the story
I was at my dads shop today (mine now) looking for some things and uncovered some really cool poplar boards he had cut from behind the acreage a few years back super colorful brown / Black / green / White...
I was going to saw it down and make some head plates. Thought it would be cool to have that connection w part of the instrument.
Upon sawingnit up and running it through the drum sander the white wood is just eaten up w holes / termite tunnels.
Bummed :/
I MAY have enough width left w the dark stuff but it will be close .
PostPosted: Fri Nov 10, 2017 4:34 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
A lot of headstocks have a 15 degree angle. I don't imagine that one more degree would matter structurally. Are you thinking about a solid headstock or a slotted headstock?
Are the holes that are visible in the photos the extent of it, or are there a bunch of tiny ones too? If the connection to the wood's history is important, you can accept the holes and make them a feature as is done with Ambrosia maple where the beetle holes are filled, either to match the wood color or to contrast with it.
PostPosted: Fri Nov 10, 2017 4:35 pm
Well under the holes are tunnels :/
PostPosted: Fri Nov 10, 2017 4:47 pm
First name: Freeman
Last Name: Keller
1 - most Gibson style headstocks are 15 or 16 degrees
2 - you could possibly fill the holes with epoxy as is sometimes done with splated wood
3 - you could easily book match two pieces of the dark wood to make a nice head plate.
PostPosted: Fri Nov 10, 2017 10:07 pm
Exactly what I did;)
Pardon the nasty glue line. Not scraped clean yet
PostPosted: Sat Nov 11, 2017 12:49 am
Last Name: Beaver
City: Lake Forest
Nice!
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 11, 2017 9:39 am
Joe Beaver wrote:
Nice!
Thanks:) here it is all finished this morning.
The seam won’t be in the middle so I don’t believe it will be noticeable
B
PostPosted: Sat Nov 11, 2017 11:36 am
That's really nice looking wood. Even though you got a good clean joint, the joint jumps out to my eye due to the interruption of the grain and color. My eye was immediately drawn to it.
PostPosted: Sat Nov 11, 2017 11:49 am
It isn’t invisible.
If I can’t hide it well I won’t use it :)
PostPosted: Sat Nov 11, 2017 11:51 am
Not seeing the offset helps a little. But still visible
PostPosted: Sat Nov 11, 2017 12:27 pm
Yes. You could probably draw the eye away from the joint or even cover it up with some inlay. Or joint in a wedge shaped piece with a highly contrasting color to make the joint look purposeful.
PostPosted: Sat Nov 11, 2017 12:43 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That’s a pretty piece of poplar. If you haven’t seen any pictures of “sun tanned” polar, google it. Apparently, sun exposure changes the colors a bit but in a really nice way.
I’ve never done it myself so you would want to experiment with scrap to see if you like it better or not.
Bryan Bear PMoMC
PostPosted: Sat Nov 11, 2017 5:16 pm
First name: Freeman
Last Name: Keller
It isn’t invisible.
My suggestion was to take two pieces and flip one over to book match them. The glue seam is the center line down the headstock. Not a very good picture (finishing going on) but this came from cuttoffs of the top wood and matches it
Users browsing this forum: No registered users and 171 guests
