It is currently Tue Jul 22, 2025 4:58 pm
PostPosted: Sun Feb 04, 2018 10:20 am
Last Name: O'Melia
City: Huntsville
State: Alabama
In the bottle. Any idea why?
PostPosted: Sun Feb 04, 2018 8:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Guess nobody seen it? Here’s a pic
PostPosted: Sun Feb 04, 2018 9:53 pm
Idk but I would definitely send it back!
PostPosted: Sun Feb 04, 2018 10:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Pumpkin spice? :D
Alex
PostPosted: Sun Feb 04, 2018 10:36 pm
First name: David
City: Napa
Zip/Postal Code: 94558
That is definitely not pumpkin spice looks more like chai latte.....
PostPosted: Sun Feb 04, 2018 10:50 pm
At least it did that in the bottle and not on your $400 Adirondack top!
PostPosted: Mon Feb 05, 2018 8:46 am
First name: Brad
Last Name: Combs
Maybe this gives a hint?
http://www.mercuryadhesives.com/wp-cont ... w-Glue.jpg
Brad
PostPosted: Mon Feb 05, 2018 8:51 am
First name: Brad
Last Name: Combs
Also, not directly related but interesting if you use the Satellite City stuff:
http://www.caglue.com/Frequently-Asked- ... celerators?
Sorry, was trying to link to this text directly:
What is the shelf life of your accelerators?
Our aerosol accelerators have a shelf life of five years. Our NCF Hot spray-pump accelerators have a shelf life of two years so long as they are kept tightly sealed with their original caps when not in use. The spray pump is not as effective in sealing the bottle as the original cap. If the bottles are not kept tightly sealed, the accelerator will turn yellow and then orange over time and will cease to have any effect on uncured cyanoacrylate.
PostPosted: Mon Feb 05, 2018 1:55 pm
I once used some cheap Chinese Walmart superglue to glue some bindings on two guitars. When initially done they looked fine. After a couple of weeks the glue turned a bright yellow, and since it had seeped into the end grain could not be sanded off. I had to do bursts on the tops to cover the stains.
I use loctite CA. It gets thicker as it ages, but I've never had it change color.
PostPosted: Tue Feb 06, 2018 6:42 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Yeah, I’m sure it aged out. As far as the bright yellow issue,that’s been discussed here a bunch. Spruce end grains can and do react to super glue by turning bright yellow.
Users browsing this forum: JimKlingshirn, Michaeldc, Stuart Flavell and 34 guests
