It is currently Sun Jul 27, 2025 2:10 am
 Post subject: Testing Hygrometers
PostPosted: Tue Feb 06, 2018 2:54 pm
City: Lawrence
Zip/Postal Code: 66047
I use potassium Bicarbonate in wine making so I have it on hand.
Rather than buy Potassium Carbonate can I use Potassium Bicarbonate to check a hygrometer?
 Post subject: Re: Testing Hygrometers
PostPosted: Tue Feb 06, 2018 3:04 pm
Potassium Carbonate is used commonly for checks because the RH of a saturated solution is 43 which is useful for us builder types, and doesn't vary a lot with temperature.
Good luck finding what the RH for a saturated solution of the bicarbonate, I googled it and had no luck.
P.S. Fortunately, Potassium carbonate is pretty cheap, try ebay?
PostPosted: Tue Feb 06, 2018 3:11 pm
City: Lawrence
Thanks Colin.Yep I tried googling it also with no luck.
I was relying on the wisdom of the group.
I may have to get a crow bar and pry my wallet open and buy the right stuff.
PostPosted: Tue Feb 06, 2018 3:14 pm
a $5.99 calibration kit won't do?
PostPosted: Tue Feb 06, 2018 5:47 pm
First name: Brad
Last Name: Combs
FWIW, the two calibration kits I saw on Amazon test at 75% and 35%. I read somewhere (maybe here :)) that assuming that the reading is linear might be a mistake. Meaning, assuming that +1 at 75% would just be +1 at 45% is not guaranteed. So the potassium carbonate test which I think hits 43% is closer to the luthier Goldilocks zone.
PostPosted: Tue Feb 06, 2018 6:26 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
https://www.amazon.com/dp/B00J5SWLK0/re ... 1_ST1_dp_1
This amount is good for years of tests.
PostPosted: Tue Feb 06, 2018 10:19 pm
City: Lawrence
Well now y'all now how cheap I am.
These users thanked the author Dave Rickard for the post: Hesh (Tue Feb 06, 2018 10:56 pm)
PostPosted: Tue Feb 06, 2018 10:58 pm
Bet I'm cheaper....
Three words:
Wet Bulb Testing
What Brad said about these various chemical tests have sweet spots for accuracy in terms of range where a Wet Bulb Test could care less. Two cheap lab thermometers and either a vac or fan and you're in business.
PostPosted: Tue Feb 06, 2018 11:18 pm
You used to be able to get those Psychro-Dyne psycrometers for pretty cheap on eBay and they are perfect for calibrating cheap hygrometers.
PostPosted: Wed Feb 07, 2018 6:48 am
City: Lawrence
[quote="Hesh"
Bet I'm cheaper.....[/quote]
They call me "Nickel Dave"
When I pry my wallet open moths come flying out
I'd bet ya but I don't want to take the risk.
Thanks guys
PostPosted: Wed Feb 07, 2018 3:10 pm
J De Rocher wrote:
https://www.amazon.com/dp/B00J5SWLK0/ref=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1
"Loud Wolf" brand.. omfg -how loud is the wolf?
PostPosted: Thu Feb 08, 2018 12:42 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I think I’m going to fill a big bucket with wet potassium carbonate in the shop and keep the door closed. Then I won’t need a hygrometer because the room will always be 43% :)
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post (total 2): Alex Kleon (Thu Feb 08, 2018 7:01 am) • Pmaj7 (Thu Feb 08, 2018 3:51 am)
PostPosted: Thu Feb 08, 2018 9:27 am
Brilliant! [:Y:]
jw ( o)===:::
PostPosted: Thu Feb 08, 2018 1:08 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Sploosh! My mind is officially blown. "No, man! We're IN the bag! Right now!"
These users thanked the author doncaparker for the post: Bryan Bear (Thu Feb 08, 2018 2:29 pm)
PostPosted: Thu Feb 08, 2018 1:22 pm
First name: Brad
Last Name: Combs
I was kind of surprised how much heat that little dish kicked out when I did this recently.
PostPosted: Thu Feb 08, 2018 11:18 pm
Last Name: Shanklin
City: Windsor
State: ON
They still are cheap on fleabay, and they are fantastic for calibrating.
Bob
PostPosted: Fri Feb 09, 2018 3:43 am
With Potassium carbonate you get a reaction that produces heat. Shouldn't be enough to set the place on fire but not sure about a bucketful.
PostPosted: Fri Feb 09, 2018 6:33 am
Last Name: Parker
City: Charleston
I suppose the bucket of wet potassium carbonate doesn’t pass the “how will I explain this to the paramedics” test. Darn.
PostPosted: Fri Feb 09, 2018 10:04 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I suppose I should say, for the record, I am not keeping an open bucket of potassium carbonate in my workshop. My typing tends to look the same whether my tongue is in my cheek or not. . .
I'm glad to hear that the reaction gives off heat though. It will give me a little more time before my hide glue gels. Wait, there I go again. . . :)
Bryan Bear PMoMC
PostPosted: Fri Feb 09, 2018 10:13 am
First name: Brad
Last Name: Combs
Porcelain dishes suspended from the ceiling approximately 3 feet above the work area. Should be able to get rid of any heat lamps you might be using.
These users thanked the author bcombs510 for the post: Bryan Bear (Fri Feb 09, 2018 10:46 am)
