It is currently Mon Apr 27, 2026 5:53 pm
 Post subject: Martin 2-17
PostPosted: Thu May 31, 2018 2:56 pm
I used to own a 1929 2-17 and it was my favorite guitar until it had to go in for a neck reset and the guys at the shop took all the mojo out of it. Never played or sounded the same, so I sold it.
Do y'all think there are plans somewhere out there that I can use to make a replica?
 Post subject: Re: Martin 2-17
PostPosted: Fri Jun 01, 2018 9:20 am
Not sure, but what do you think could have happened during the reset? Was it a reputable shop and did you talk to them about it?
Sent from my SM-N910T using Tapatalk
PostPosted: Fri Jun 01, 2018 9:27 am
The size 2 is similar to the size 1 in most respects but with slightly narrower bouts ( 3/4 inch narrower low b.) and a slightly shorter scale length. (1/4 inch shorter). You could adapt a size 1 plan or use Antes parlor plan (which is more of a Washburn shape).
PostPosted: Fri Jun 01, 2018 11:06 am
First name: Freeman
Last Name: Keller
The Guild of American Luthiers has a set of plans for a 1-18. Antes calls his parlor plans a "small concert", it is 18-3/8 long and about 12 wide.
PostPosted: Fri Jun 01, 2018 11:13 am
Thanks for the responses. Are there any parlor sized 12-fret kits I can give a try in the mean time before I get too obsessive? Preferably with a 24 7/16 inch neck or in the ballpark.
PostPosted: Fri Jun 01, 2018 11:21 am
It was years ago. They brought the action down too far. Cleaned up all the aged bits when I told them to leave it alone, so it looked liked a brand new guitar instead of from the '20s. And it took them many months, so I wasn't going to wait around again. They didn't follow any instructions, basically.
PostPosted: Fri Jun 01, 2018 11:46 am
First name: Freeman
Last Name: Keller
LMI sells a kit that pretty well matches the Antes parlor plans. As I recall they provide a 24.625 scale fretboard and neck with the kit while the plans call for 24.5 inch scale (it is a pretty simple matter to move the bridge). I have built three guitars from the Antes parlor plans and I really like that size guitar. The LMI kit wizard lets you customize the materials and the amount that you want them to do for you which is a really nice feature.
The Antes plans do have a couple of things to be aware of, if you decide to built one I can help with that. Here is a typical LMI kit
Here are two of the Antes parlors
One nice thing is that they fit in a commercially available case
Little anecdote. I submitted one of those guitars to the Steel String Listening Seminar at last years GAL convention (builders submit guitars to a single player who plays the same thing on each. The builder describes the guitar, answers questions.) After the seminar someone came up and commented on how they liked the guitar and how well it projected. I asked where they were sitting, they said the very back of the hall. For a small guitar these are remarkably loud.
PostPosted: Fri Jun 01, 2018 2:39 pm
Freeman,
They're beautiful. I have an immense fondness for small, lightweight guitars. [clap]
