It is currently Wed Jun 10, 2026 8:31 am
PostPosted: Thu Jun 21, 2018 1:29 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Has anyone tried this,ive got a sample coming.
PostPosted: Thu Jun 21, 2018 5:38 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Never heard of it. Looks pretty expensive.
Please share your findings.
I'm not a luthier.
PostPosted: Thu Jun 21, 2018 7:38 am
Last Name: Sankey
City: Ottawa
I've used it on one guitar so far, and I know some people who have used it on a few acoustics. Is your sample the two-part kind? That's the one that I think is more useful.
It's more or less like a tru-oil type finish, but it cures completely in one day, even on rosewoods and other oily exotics, which is pretty amazing. I like to scuff with a fine scotchbrite pad and do an extra coat to make sure I've achieved complete coverage.
It is pretty expensive, but you only need to mix up a tablespoon or so for a whole guitar so it goes a long way. It's quite viscous, so it doesn't sink it too fast, but you have to work more to spread it around. On flattish surfaces it makes sense to use a credit card or plastic scraper.
So far it seems to be very tough and water/beer resistant. It also seems to keep its colour well, unlike Livos which tends to turn yellow on light-coloured woods.
So it's promising. But of course, test on some scraps, and then on some non-guitar things to make sure you've got the hang of it.
PostPosted: Thu Jun 21, 2018 8:27 am
First name: robin
City: andover
State: hants
Country: uk
Just got the sample, its the one part type they allso sent an applicator which is like a rough sponge type thing, how did you apply yours Mike and what grit did you sand to before application.Thanks Rob.
PostPosted: Thu Jun 21, 2018 8:35 am
I too would love to see some pics and hear what you think about it.
PostPosted: Thu Jun 21, 2018 10:31 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I've used something similar on some electric guitars I've done, (at least it seems like a similar product). A product called Osmo. The guitars look and feel amazing, really alive.
I sanded up to 1000, and then the first coat of oil I applied with a cloth wrapped around a paper towel, really tried pushing it into the grain and let it set up, then took a white scotch brite pad and applying pressure rubbed the whole thing down to burnish that first coat, then wiped off excess.
It hasn't proved to be the most durable of finishes, but I love worn in guitars and this finish has left the guitar feeling really resonant.
These users thanked the author Conor_Searl for the post: Pmaj7 (Thu Apr 16, 2026 1:00 pm)
PostPosted: Thu Jun 21, 2018 9:37 pm
Last Name: Sankey
City: Ottawa
I think your Osmo might be a different thing Conor, rubio is really tough. They even suggest using it on floors...
The one-part finish is supposed to have the same characteristics as the two-part, but takes much longer (i.e. several days or more) to cure. That's why I wouldn't bother with it.
I believe there are detailed application instructions on the website, and that it would be best to follow them. I was told how to use it by a friend, and they said not to go beyond 400 grit (I use 3M gold), since if you go higher it might absorb more unevenly. I just used a rag to apply, but by all means use their plastic gizmo. The trick is to cover the whole piece quickly and thoroughly so you get even absorbtion; uneven application could result in uneven colour and depth. I didn't have any problems though, so maybe my concerns are overblown. Then you wait a couple of minutes and soak up all the excess with a clean rag.
Hope this helps.
These users thanked the author Sankey Guitars for the post: Pmaj7 (Thu Apr 16, 2026 1:02 pm)
PostPosted: Thu Jun 21, 2018 10:12 pm
First name: Conor
Last Name: Searl
City: Duncan
Osmo is for floors too. I just looked them both up online and they're compared to each other with a couple other products. It's called Poly X. I get mine from a furniture maker, and followed the instructions he uses for doing tables. When I say it's not as durable I'm talking about fingernail scratches, pen marks (I use my guitars as tables when I teach lessons ;)) and shirt buttons. Having said that my lacquered strat has suffered terribly from shirt buttons too.
PostPosted: Thu Apr 16, 2026 1:06 pm
Thinking about giving this a try. Anyone else using it?
Currently I use 4 coats of Tru-Oil. I like it for a natural wood feel and is really nice on figure. I am NOT going for a gloss with this like I have heard some doing. I just wipe on then wipe off 4 times. Sounds like this 2-part Rubio Monocoat can do it in 1 coat.
PostPosted: Thu Apr 16, 2026 7:25 pm
I am about to try a U.V.cured oil called Clean Armor....
These users thanked the author Brad Goodman for the post: Kbore (Sat Apr 25, 2026 9:57 am)
PostPosted: Fri Apr 17, 2026 3:52 am
I've used the 2 part Rubio for B & S, but TBH, I prefer the Osmo PolyX,
The monocoat is expensive too.
Here's the Monocoat https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=54593&p=747343&hilit=rubio#p747343
These users thanked the author Colin North for the post: Pmaj7 (Fri Apr 17, 2026 7:23 pm)
PostPosted: Fri Apr 17, 2026 8:12 am
Anyone have a link to their application schedule for the Osmo? I’ve got some but haven’t tried it yet. If not I’ll start a separate thread.
PostPosted: Fri Apr 17, 2026 8:32 am
First name: Brad
Last Name: Combs
Steve, search “House Guitars Osmo” on YouTube. Josh’s tutorial is what I use and its worked well. Good luck! Osmo is the best! :D
Brad
These users thanked the author bcombs510 for the post (total 3): Kbore (Sat Apr 25, 2026 9:57 am) • Pmaj7 (Fri Apr 17, 2026 7:16 pm) • SteveSmith (Fri Apr 17, 2026 9:05 am)
PostPosted: Fri Apr 17, 2026 9:05 am
Awesome, thanks Brad!
These users thanked the author SteveSmith for the post: bcombs510 (Fri Apr 17, 2026 11:33 am)
PostPosted: Fri Apr 17, 2026 9:41 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Warning on Osmos Poly X.
Do not use on raw Granadillo.
I did on a small table I made. Looked great going on but after 24 hours it developed a very chalky residue all over. I contacted Osmo and they told me to wipe down with mineral spirits. I did and the results did not improve. They claimed the wood was contaminated so I scraped the finish off the table to bare wood and reapplied. Same results. Osmo threw up their hands and stopped communicating.
I had used Poly X on cherry and received great results.
These users thanked the author Gasawdust for the post: Pmaj7 (Fri Apr 17, 2026 7:17 pm)
PostPosted: Fri Apr 17, 2026 9:47 am
I tested with 1 coat and 2 coats, with and without a water based paste filler and IMHO 2 is better, one can be patchy (even with a lot on excess applied), on EIR and Madrose anyway.
There are several furniture maker you tube videos who advise more than one coat.
These users thanked the author Colin North for the post: Pmaj7 (Fri Apr 17, 2026 7:17 pm)
PostPosted: Fri Apr 17, 2026 10:49 am
City: U.P.
Has anyone checked into applying finishes over Rubio or Osmo. Being a hard wax/oil finish I'm curious about repair options down the road and possible adhesion issues do to the wax.
I have some Osmo but have only used it on some test coupons so far. If memory serves me, I think I asked about refinishing over it and I think they said it could be a problem.
Also, I think the Rubio site said "pre-finished" wood needed to be taken back to raw wood for the chemical bond to form. Made me wonder about use over shellac sealer, or other sealers we commonly use or even pore fills.
I'm always full of questions, especially with finishes.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Pmaj7 (Fri Apr 17, 2026 7:18 pm)
PostPosted: Fri Apr 17, 2026 6:47 pm
I finished a guitar in 20 minutes today with the clean armor finish ,so far so good -I like it…
These users thanked the author Brad Goodman for the post (total 3): Kbore (Sat Apr 25, 2026 9:58 am) • rbuddy (Fri Apr 17, 2026 7:35 pm) • Pmaj7 (Fri Apr 17, 2026 7:27 pm)
PostPosted: Fri Apr 17, 2026 7:21 pm
Wow looks good BradG! Which specific one did you use? Soundboard too? 1 coat?
PostPosted: Fri Apr 17, 2026 7:22 pm
Wow, looks good BradC! And look at those mahogany silks!
PostPosted: Fri Apr 17, 2026 7:24 pm
Colin, having used both, what did you like/not like about each?
PostPosted: Fri Apr 17, 2026 8:32 pm
I used the Matte-2 coats...
These users thanked the author Brad Goodman for the post: Pmaj7 (Sat Apr 18, 2026 3:26 pm)
PostPosted: Fri Apr 17, 2026 8:33 pm
Pmaj7 wrote:
Wow, looks good BradC! And look at those mahogany silks![/quote
Actually it's Eastern Walnut..
