It is currently Mon May 18, 2026 11:30 am
 Post subject: X-brace height
PostPosted: Wed Sep 05, 2018 1:26 pm
First name: Brad
Last Name: Combs
Hello,
I made an adjustment to the jig I’ve been using to make the x-brace and didn’t catch that the result is 12.5mm height at the center instead of the 14.5mm I had been using. It had to do with how much of the brace was exposed in the radius jig which caused it to be shorter.
There are a lot of factors here, but I wonder what some of the typical heights are that you end with after voicing your tops? Is 12.5 (roughly 1/2”) asking for implosion city?
FWIW, I use 12.5 for the tonebars usually.
I think I’m asking for trouble and will likely just make a new jig that gets me back to where I was before. In any case... thoughts?
Brad
 Post subject: Re: X-brace height
PostPosted: Wed Sep 05, 2018 1:44 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Based on Martin and Gibson dreadnought plans, my x-braces are 5/8" tall at the X for dreadnoughts. X-braces for my smaller body guitars are 1/2" tall at the X.
These users thanked the author J De Rocher for the post: bcombs510 (Wed Sep 05, 2018 1:45 pm)
PostPosted: Wed Sep 05, 2018 3:47 pm
Yep, 5/8 for dreads and OM/000 and 1/2 for size 2’s.
These users thanked the author Terence Kennedy for the post: bcombs510 (Wed Sep 05, 2018 5:40 pm)
PostPosted: Wed Sep 05, 2018 4:08 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
The D-35 x-bracing is 1/2"x 5/16"...essentially 000 bracing for the back and 00 bracing on the top. They seem to hold up about as well as most of the other 1960's and 1970's versions of the dreadnaught.
These users thanked the author Woodie G for the post: bcombs510 (Wed Sep 05, 2018 5:40 pm)
PostPosted: Wed Sep 05, 2018 7:49 pm
Same as JD and TK. It's all part of the system though. Where does your scallop start, how aggressively you thin them, Bridge plate, xcap, etc.
These users thanked the author Pmaj7 for the post: bcombs510 (Wed Sep 05, 2018 9:49 pm)
PostPosted: Thu Sep 06, 2018 11:31 am
I tend to end up with the X braces about 1/2" at the crossing on six strings, more or less. A lot will depend on how thick you make your top, and the wood, of course.
These users thanked the author Alan Carruth for the post: bcombs510 (Thu Sep 06, 2018 11:41 am)
Users browsing this forum: No registered users and 273 guests
