It is currently Sun Apr 26, 2026 7:01 pm
PostPosted: Tue Feb 05, 2019 12:41 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
I have some rosewood back plates - approximately 8x22 that are warped.
I am looking for suggestions on how to flatten them.
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 05, 2019 1:07 pm
Dampen, wrap in ulu foil and iron them flat, sticker.
PostPosted: Tue Feb 05, 2019 2:11 pm
PostPosted: Tue Feb 05, 2019 2:17 pm
First name: Larry
Last Name: Hawes
https://www.youtube.com/watch?v=0emWxl67tF0
Thank You and Best To All
PostPosted: Tue Feb 05, 2019 2:25 pm
Do not iron if there is wax present. Hot wax will flow like water into the wood and never come out. It may compromise future glue joints and some finishes.
I did the following once on a set of BRW with 1/4" backs. However, in hind site, I am guessing that you could just put the pieces into a heavy duty plastic bag with water for a couple of weeks. Anyway, here is what I did. Needs a metal free container to submerge the wood. For the sides, I made a rectangle of 2.4 on the floor and draped a heavy duty plastic in it. For the backs, they fit in a fiberglass utility sink. I put some weights into plastic bags to hold the wood under water. At first no change and you could not force them flat. After what I recall as at least a week, the wood finally just relaxed to its original shape after sawing. I then stickered and weighted it and it has been fine.
