It is currently Thu Aug 07, 2025 4:01 am
PostPosted: Tue Mar 26, 2019 5:44 pm
Anyone who's successfully used Macassar Ebony for B & S- what sort of thickness did/would you use?
If I target a similar weight as my "normal" EIR back thickness it would be ~ 1.975 mm or 0.78".
Too thin? OK?
PostPosted: Wed Mar 27, 2019 9:31 am
I did an om with macassar ebony and I think the back ended up at close to .07. It just felt too heavy when it was thicker. Still plenty stiff.
Sent from my SM-N910T using Tapatalk
These users thanked the author Pmaj7 for the post: Colin North (Wed Mar 27, 2019 11:07 am)
PostPosted: Sun Mar 31, 2019 8:15 am
Personally I would leave the back thicker and go for a "reflective" back rather than a "responsive" one. I think the dense less oily woods (ebonys, ziricote, etc) are more brittle and crack prone when worked too thin. That is my impression,from the limited amount I have worked with them, others may know better.
These users thanked the author Clay S. for the post: Colin North (Sun Mar 31, 2019 8:21 am)
PostPosted: Sun Mar 31, 2019 11:57 am
City: U.P.
I have a macassar guitar going right now. I got several back sets 5 or 6 years ago and they were all on the thin side and this one was the worst with an area around 0.07" that I massaged into the waist as best I could. Sanded thickness was around 0.075, with one small area near a waist that had to be hand sanded to almost 0.065. A bit thinner than I would have preferred. But I really wanted to build with the macassar so figured the worst back set I had was a good place to start. This being only my 6th guitar and one of a group of 3 I'm working on at the same time. This one has been a closed box for a year now and seems plenty solid and I'm not worried about back strength.
My experience with macassar is that it is pretty tough stuff and seems less likely to split than most other guitar wood. I would probably shoot for back thickness of 0.08 to 0.085 but at 0.075 it seems quite OK. I really like macassar to work with.
Brian R
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Colin North (Sun Mar 31, 2019 2:36 pm)
PostPosted: Sun Mar 31, 2019 2:37 pm
Nice looking build Brian!
These users thanked the author Colin North for the post: rbuddy (Sun Mar 31, 2019 3:27 pm)
PostPosted: Mon Apr 01, 2019 12:11 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I would go with 0.075".
These users thanked the author John Arnold for the post: Colin North (Mon Apr 01, 2019 12:14 pm)
