It is currently Thu Apr 23, 2026 4:31 pm
 Post subject: spraying shellac
PostPosted: Fri Feb 14, 2020 8:43 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I want to spray zinsser seal coat which is a 2lb. cut. Do I have to thin it and what size nozzle do I use with my fuli hvlp. Also how low of temperature can I live with?
Mike McNerney
 Post subject: Re: spraying shellac
PostPosted: Fri Feb 14, 2020 9:34 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
You can wipe on a 2# coat in just a few minutes and not have to deal with the spray equipment clean up or runs in the finish. I'm not a Zinzer fan because I've seen it not dry due to unknown age in the can, but I do the 2# wipe on seal coat on every instrument I make.
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Sat Feb 15, 2020 8:45 am
Some people do spray shellac, but if you are just doing a seal coat I agree with Bob - wiping on a thin coat with a rag is much less work and will give a better result. Misting on a couple of thin coats from an aerosol can will also work.
Shellac is a sticky finish that likes to gum up spray guns. If sprayed too heavily it dries slowly and attracts dust and it doesn't sand particularly well.
But some people have sprayed shellac with success. Chuck Tweedy on the MIMF sprayed it as base coats which he later French polished over top of. If you don't get any good information here you might check the Archives there, or ask your question there (I think Chuck still stops in there from time to time).
PostPosted: Sat Feb 15, 2020 8:59 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I've had good results with Zinsser rattle-can shellac. Sure is easy to set up and clean the gun. Also no worries about thinning. No comment so far from OP concerning the reason for shellac coatings, and it matters. Seal coat? final finish? It all matters.
Peter Havriluk
PostPosted: Sat Feb 15, 2020 9:38 am
not a fan of spraying canned shellac wiping is easy fast and neater
PostPosted: Sat Feb 15, 2020 10:36 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
OK let me add some new details. I am considering doing the entire finish in shellac. My experience with first coats of almost anything is pretty easy. i will be brushing or wiping my first coat of shellac. but after that I have had lots of issues getting it even. So i would like to try spraying. How long should i let shellac dry between coats so i don't have to worry about shrinking. after the last coat, again how long should I wait, i wanted to try the FP alochol pad thing.
Mike McNerney
PostPosted: Thu Feb 20, 2020 9:27 pm
Mike! I've sprayed shellac a lot on my guitars. I use it as a wash coat on almost all my projects. I don't change nozzles on my HVLP. I think it's a 1.2 on there, so it lays it down pretty thick. I have to be very careful or it will run. If you want, we can exchange ideas over a nice bottle or red wine... ;)
I've moved over to using pre-cat lacquers, mostly, but shellac was always my first love.
Cheers,
A
Oh, and I'll PM you my phone number. I haven't been on here in almost a year, I think. Life (and my lengthy renovations) are still getting in the way of my guitar building enjoyment...
These users thanked the author Alain Desforges for the post: Zac Stout (Fri Feb 21, 2020 1:23 pm)
Users browsing this forum: Alan Carruth and 22 guests
