It is currently Tue Apr 21, 2026 7:35 am
 Post subject: X brace height
PostPosted: Thu Mar 26, 2020 5:12 pm
I’ve seen some pretty fantastic variance in how high ppl like to leave the x brace height before things taper down.
I know tops car vary, but where do you start from?
 Post subject: Re: X brace height
PostPosted: Thu Mar 26, 2020 6:19 pm
Last Name: Colbert
City: Anacortes
My x-brace starts @ 1/4"x 5/8". UTB starts @ 5/16"x 13/16". My typical x-brace intersection ends up about 1/2" tall after carving.
Best, M
These users thanked the author Michaeldc for the post: SnowManSnow (Thu Mar 26, 2020 6:51 pm)
PostPosted: Fri Mar 27, 2020 7:33 am
Can depend on the type of body OM, Dread, etc but currently I'm using X Braces at 0.256 x 0.550" with very light (SG=.036) stiff spruce for an OM.
Last one turned out just fine.
PostPosted: Fri Mar 27, 2020 8:17 am
I am building two OM's now and they are at 13mm, a hair over 1/2in. A dread would be taller, probably a full 5/8th. So yeah, it all depends.
PostPosted: Fri Mar 27, 2020 4:39 pm
5/8" is a very safe number. That's where I start, and end up between 5/8" and 1/2” by the end, depending on the response I'm getting when I tap. I've also moved to tapping with the top glued to the rim before the back is on.
PostPosted: Sat Mar 28, 2020 6:19 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Hope this helps...
Note that the center graft starts at 1/8" thickness, but between planing with a skew block plane to remove go-bar dents and shaping, final size is usually at or just over 0.080" maximum thickness.
These users thanked the author Woodie G for the post: Colin North (Sat Mar 28, 2020 8:07 am)
PostPosted: Sat Mar 28, 2020 8:13 am
Thanks Woodie G, nice timing, I'm replacing a maple BP with a rosewood one on a build and just about to thickness it.
