It is currently Sat Aug 02, 2025 7:22 am
PostPosted: Sun Feb 28, 2021 3:11 pm
First name: Nathan
Last Name: Peirson
Hi folks, I have a Fender acoustic bass with a pinless bridge. When I got it the bridge was cracked down where the ball end lives. I assume the prior owner was putting strings with larger ball ends and cracked the bridge. My question is, can I replace that bridge with a traditional pin style bridge? I assume I would have to add a bridge plate, but I wonder if there are any other considerations I should be aware of? As always, thank you for your responses.
PostPosted: Sun Feb 28, 2021 7:39 pm
If you want to go that route, I think the main concern would be maintaining the structural integrity of the braced top. So make sure that none of the new bridge pin holes intersect a top brace. And you are correct that a bridge plate will be necessary. I like to use hard maple but rosewood is acceptable too.
These users thanked the author Barry Daniels for the post: nathanpeirson (Mon Mar 01, 2021 2:26 pm)
PostPosted: Sun Feb 28, 2021 8:50 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I suggest OP put an inspection mirror in the soundhole and see if there's already a bridge plate present. I think they're used to stiffen the bridge/top/bridgeplate lamination and only incidentally used to retain string ball ends.
Peter Havriluk
These users thanked the author phavriluk for the post: nathanpeirson (Mon Mar 01, 2021 2:26 pm)
PostPosted: Sun Feb 28, 2021 11:11 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Nathan,
I've built two ABGs, one with with a pinless bridge that had a substantial bridge plate per the Mark Stanley plans. The other that still needs finishing will have a Martin pinned bridge ( I got a Martin 2nd fretboard/neck and bridge somewhere). Both have Maple bridge plates. I think it's most important to have the wings of the bridge over the x-braces.
These users thanked the author CarlD for the post: nathanpeirson (Mon Mar 01, 2021 2:25 pm)
Users browsing this forum: Bing [Bot] and 33 guests
