It is currently Mon Jul 21, 2025 9:37 am
PostPosted: Thu Sep 16, 2021 1:45 pm
First name: STEVE
Last Name: LEONARD
State: AL
Zip/Postal Code: 36312
Ok did a search and could not fine a suitable answer.......I'm using an open scale length of 21.375" for the guitar I'm building. What sort of tolerance do I have with that? I am trying to put the bridge plate in the right place! I have a finger board slotted for that scale.
Thanks!
Steve Leonard
SEleonard
PostPosted: Thu Sep 16, 2021 2:10 pm
Check out the StewMac Fret Scale Calculator. You can plug in scale length and other info then it will calculate the compensated lengths to the center of the saddle for the high and low E strings. You can use that length to determine where the saddle and, therefor, the bridge must go. That will let you place the bridge plate. I try to keep my measurements using rulers to +/- 0.01" since that's the best I can see with my optivisor.
PostPosted: Thu Sep 16, 2021 2:15 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Here is a pretty handy guide:
https://www.stewmac.com/fret-calculator/
Once you use the calculator, look to the bottom for info on bridge placement. From that info, you should be able to figure out where to put the bridge plate.
EDIT--
Duplication of Steve's post.
PostPosted: Thu Sep 16, 2021 3:06 pm
Define tolerance. For what?
PostPosted: Thu Sep 16, 2021 3:23 pm
For a bridge plate you should have plenty of tolerance. I would aim to put the saddle at 21.475 and make the bridge plate extend 1/8th inch wider than your bridge. That will give you plenty of fudge factor.
PostPosted: Thu Sep 16, 2021 4:02 pm
Like JF I make my bridge plates a little bigger than the bridge so they extend a little in front and behind the bridge.
PostPosted: Sat Sep 18, 2021 2:19 pm
Last Name: Orr
Thanks!
Do you mean the bridge on top of the guitar or the bridge plate inside the guitar, not the same thing.
PostPosted: Tue Sep 21, 2021 7:34 pm
You have very little tolerance on a guitar with that short of a scale. The shorter the scale the more important the compensation will be, so study it out and set the bridge exactly. Take your time!
Users browsing this forum: stumblin and 21 guests
