It is currently Mon May 25, 2026 2:38 pm
PostPosted: Sat Jan 08, 2022 9:32 am
Hi, I'm about to buy the classic filtertron pickups from mojotone. After looking at the diagram, it seeams like they are too large to fit regular pickup rings. I'm building a hollow body so there's nothing solid for the pickups to mount onto directly. I'm buying the pickups from Sweetwater so if anyone can direct me to a perfect match from there, that'd be very helpful. It there aren't any, I guess I have to built my own rings.
PostPosted: Sat Jan 08, 2022 12:58 pm
I would be asking the people who pedal the pups this is not a very active electric guitar forum. Ask Fred at Mojotone or Sweetwater if they sell the stuff they really should know what rings work.
PostPosted: Sat Jan 08, 2022 2:00 pm
You should be able to get a standard humbucker set and trim them to fit.
These users thanked the author Barry Daniels for the post: Hesh (Sat Jan 08, 2022 3:03 pm)
PostPosted: Sat Jan 08, 2022 5:11 pm
StewMac has them. If there is a significant contour to your top you may have to make your own.
https://www.stewmac.com/parts-and-hardw ... ting-ring/
PostPosted: Sun Jan 09, 2022 8:32 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Good advice - Mojotone was in an all-out sprint to catch up on back orders last time I checked, but they were still picking up the phone...luxury service in our new viral reality.
The shop where I worked used a woodworking-style wheel marking gauge to scribe the plastic parallel to the outside edges of the ring and a radius template (the plastic drafting tool works, as well as a machinist's steel template) to accurately move the corner radius out to the new line. A razor-blade scraper and a fine-toothed round file did the job, with some very low rpm polishing on the freshly worked edges of the plastic with a felt polishing bit loaded with some medium Menzerna or suitable plastic polishing compound.
Users browsing this forum: Kbore and 23 guests
