It is currently Wed Jun 10, 2026 6:17 am
 Post subject: Bolt spacing M/T
PostPosted: Tue Jan 25, 2022 7:46 am
First name: Brad
Last Name: Combs
Hi folks,
I’m interested in knowing what bolt spacing is most used with M/T necks. Does it vary between the sizes you build?
What I’m interested in is the distance from the edge of the tenon (fretboard side) to the first bolt and then the distance to the second bolt.
In Robbie O’Briens course he uses 1.125” from the edge and then another 1.125 to the second bolt. That’s for a dred. I’ve used that same spacing on all my guitars including parlor bodies too.
Also, if you wouldn’t mind sharing the attachment type you use - hanger bolt, cross dowel, threaded insert, etc… that would be great.
Thanks!
Brad
 Post subject: Re: Bolt spacing M/T
PostPosted: Tue Jan 25, 2022 8:08 am
Last Name: Colbert
City: Anacortes
Hi Brad,
I do 1-1/4 and 2-1/2 from the underside of the guitar top with a 13/16” x 10mm x 1/4-20 dowel - Ala Cumpiano. I use the exact same neck block in everything I build from my “0” thru to my 28” FF Baritone. The neck block extension is the variable - it gets cut to length prior to glueing it to the rims. I usually batch up 10 neck blocks at a time, so having them be identical is quite handy.
Best, M
These users thanked the author Michaeldc for the post: bcombs510 (Tue Jan 25, 2022 9:59 am)
PostPosted: Tue Jan 25, 2022 9:30 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
So as to mitigate analysis paralysis, I suggest picking, and sticking with, one dimension. Different body heights can be accommodated by lopping off the bottom. Advice above sounds appropriate to me.
Peter Havriluk
These users thanked the author phavriluk for the post: bcombs510 (Tue Jan 25, 2022 9:59 am)
PostPosted: Tue Jan 25, 2022 10:00 am
First name: Brad
Last Name: Combs
Thanks.
To clarify - I’m taking a survey not looking for recommendations on what I should do. I have a method that works. I am hoping to get a sense of what the group does as I’m considering it in a tool design.
Thanks!
Brad
PostPosted: Tue Jan 25, 2022 10:31 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Brad--
You and I have discussed this a bit, but here is more info:
I am currently building with a dovetail, but if/when I build more bolt-ons in the future, I think I would want to use the Gore/Gilet attachment method. I have used threaded inserts. I would use them again, but I would make sure to use a wooden dowel in the heel. I have used the dowel nut/cross dowels. I know they are popular, and mine worked fine, but they are not my personal preference. The Gore/Gilet method looks really solid to me. Other than needing access to a benchtop mortiser (or a drill press attachment), I don't see a downside to their method.
I have not used hanger bolts, but if I did, I would want to use a wooden dowel in the heel, like with the threaded inserts. Maybe that is overkill, but there is something worse than overkill: Underkill.
These users thanked the author doncaparker for the post: bcombs510 (Tue Jan 25, 2022 10:50 am)
PostPosted: Tue Jan 25, 2022 2:52 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
The spacing between the bolts/barrel nuts in my M/T necks is the same across all instruments.
I don't use the fretboard edge of the tenon as the reference point for locating the bolts. I use the bottom of the heel as the reference point because I want to keep the bottom bolt the same distance from the bottom of the heel in all instruments. The bottom bolt has the greatest leverage of the two bolts against rotation of the neck under string tension, so I want to keep it close to the bottom of the heel. I won't go into how I decided on the distance from the bottom of the heel shown below since that has to do with the particulars of how I build my necks, but it stays the same across instruments. Because of that, the distance between the top bolt and the fretboard edge of the tenon varies between instruments that have different body depths at the neck.
I use 3/8" diameter barrel nuts with #10 socket head bolts and the tenon is cross grain laminated.
These users thanked the author J De Rocher for the post (total 2): Robbie_McD (Sat Feb 19, 2022 6:13 pm) • bcombs510 (Tue Jan 25, 2022 3:41 pm)
PostPosted: Sat Feb 05, 2022 4:57 pm
First name: Terry
First bolt 1 1/4" from the under side of the top plate (top of the head block). Second bolt, 1 3/8" from the first bolt. Both 1/4" bolts with the barrel nut (LMI). I do this on Jumbo, Dread and Parlor. That said I actually measure from the bottom of the Head block blank, as it's not practical to measure from the top once the block is all glued up, shaped and ready for drilling.
I don't drill the holes in the neck Tennon until final neck fit. I put the neck on as it will live in the finished guitar and use a brad-point bit through the inside of the guitar with a light tap to mark where the holes should be drilled in the neck Tennon. I drill the barrel nuts last, based on those marks.
These users thanked the author TerrenceMitchell for the post: bcombs510 (Sat Feb 05, 2022 5:30 pm)
PostPosted: Sat Feb 05, 2022 6:28 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
What Terrence said as far as spacing and also important to fit neck before drilling holes. I made a jig to help with that. It's built out of aluminum but you can use wood.
PostPosted: Sat Feb 05, 2022 6:55 pm
First name: Jay
City: Bothell
State: Washington
As further proof that there's more than one way to skin this cat, after fitting the neck to the body, I drill the barrel nut holes and then the bolt holes in the tenon and use dowel centers in the tenon bolt holes to mark where to drill the bolt holes in the headblock. After drilling those, I follow up with a reverse spot facer to make recesses for the bolt heads and washers on the inside face of the headblock
PostPosted: Sun Feb 06, 2022 6:23 am
State: West Somerset
Country: UK
Plus one for the Gore Gilet method.
There is one small downside. You have this big brass bar up the heel which means you can't really screw a strap pin right on the heel as some like to do. There could be ways round that but what I do is pu the pin above the heel, into the top of the upper bout with a block glued in to take the screw.
Also in general the bolts need to clear any tranverse braces you have going on around there.
PostPosted: Sun Feb 06, 2022 9:59 am
First name: peter
Last Name: havriluk
City: granby
State: ct
My neck blocks have an extension that bridges between the neck block proper and the upper transverse brace in front of the soundhole. I drill my bolt holes so as to allow room to swing a driver for the cap screws inside the body.
Peter Havriluk
PostPosted: Sun Feb 06, 2022 12:44 pm
Brad I didn't read any of the posts so forgive me if this is redundant.
Whatever you arrive at measure and locate where a strap button would typically be installed and then see if your hardware selection and positioning permits a hack in a big box music store to not **** ** your guitar when they learn the hard way about using rate earth magnets to locate hardware on bolt-on necks before going for the drill....
It's a very common problem that people try to install strap buttons and then hit a bolt....
PostPosted: Sat Feb 19, 2022 5:30 pm
First name: Terry
Fair point. It's really about what set of holes are your reference, understanding that either set are close enough to the ideal. I have considered using the method described above (using pen turning reamers to generate the recess for the bolt heads) but I came the the conclusion that the harder set of drilling operations to execute, in terms of precision, were the holes and the recesses in the head block. So, I'm very carful to do those holes and recesses based on the bolts I'm using, and what I feel is an appropriate thickness of head block to support the bolts. Then I do the tennon drilling off of those neck block holes once the neck has been fit.
In a carefully made guitar, I don't think either method will put you out more than 1/32" from the intended design, so it's a matter of preference to me. I just didn't want to mess with the "blind" operation of doing the drilling of those holes and recesses inside the body.
Users browsing this forum: patmguitars and 15 guests
