It is currently Sun Aug 03, 2025 3:26 am
 Post subject: Dreadnaught Plans
PostPosted: Mon Jun 26, 2023 2:15 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I'm putting a Martin D18 on my build list. The first guitar wood I bought, maybe 5 years ago, is still on the shelf with a rubber band around it. Yesterday I brought some wood back from Appalachian Tonewood, and the Hemlock set is pretty big. The bearclaw on the stuff I bought with mahogany back, sides, and neck is smaller than the mahogany. It's only 14.5" or so wide; a 00? The Hemlock and Mahogany could do 17" so size isn't a problem.
I don't know anything about the sizes, and bling specs; but apparently a D18 was a very early steel string; with a mahogany back and sides. So it could look similar to something real.
I see a plan for a Dreadnaught on gen-one luthier supplies, and not much else. Looks like it would get me there. Anyone used that plan?
Why be normal?
 Post subject: Re: Dreadnaught Plans
PostPosted: Mon Jun 26, 2023 2:32 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I havent used the Dreadnaught plan specifically from Gen-One but I did download their 00 plans and they are pretty good.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Mon Jun 26, 2023 3:26 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Stew Mac has a decent dred plan, You need about 16 inches for the back,
PostPosted: Mon Jun 26, 2023 4:21 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I used the Stew-Mac 'herringbone' dreadnought plan, reduced in size, as my starting point for my scratchbuilt guitars. I found I could learn a lot by looking.
Peter Havriluk
PostPosted: Mon Jun 26, 2023 4:45 pm
First name: Brad
Last Name: Combs
I’ve used the LMI plan as a starting point - https://www.lmii.com/plans/3326-plan-dr ... tring.html
PostPosted: Mon Jun 26, 2023 10:00 pm
First name: David
City: Napa
Zip/Postal Code: 94558
I would talk to John Hall, he is the resident Martin expert and has plans for sale. Plus he's great to work with and offers all sorts of jigs.
PostPosted: Tue Jun 27, 2023 1:36 am
I haven’t seen the plan you mention, but my dread plan is also based on Stew-Mac’s ‘herringbone’ plan which I believe is a D-28.
PostPosted: Tue Jun 27, 2023 5:22 am
avoid gen one it is not accurate
the stew mac herringbone and Cadguitar plans are good
the only thing is they are D28
the main difference is
A no neck diamond or valoute
B Obviously Mahogany not Rosewood
C the rosette uses a specific trim
We have that at blue creek .020 black inner and outer ring the rosette double the top purfling for the 1 9 1 rosette
D the D 18 used both ebony and rosewood as the fretboard and bridge material Dots are 1 .250 .156 and .187 paua
E binding is usually tortoise or black the tail piece matches the binding and the heel cap can also be matching or rosewood
other than that they are similar in size and shape
in 1939 the bracing changed to rear shift and the nut width went from 1 3/4 at the nut and 2 5/16 at the bridge to 1 11/16 at the nut and 2 1/8 at the bridge.
PostPosted: Tue Jun 27, 2023 10:18 am
First name: Ken
Last Name: Nagy
City: Goodrich
Thanks John. I'll get a better plan. The belly will be this piece of Hemlock. It already has the outline on it! It has some character.
Why be normal?
These users thanked the author Ken Nagy for the post: doncaparker (Tue Jun 27, 2023 10:36 am)
PostPosted: Tue Jun 27, 2023 10:38 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I'm very interested to see how the Hemlock turns out, Ken.
PostPosted: Tue Jun 27, 2023 10:51 am
Hemlock is brittle and tends to crack.
PostPosted: Tue Jun 27, 2023 11:09 am
First name: Dan
Last Name: Miller
City: Cape Vincent
Zip/Postal Code: 13618
I've used hemlock timbers on several of my timber framed buildings. Nasty stuff! At least the horses won't eat it, so there is that. :D
PostPosted: Tue Jun 27, 2023 3:59 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Thanks for the the heads up John.
I had a Red Spruce violin belly that kept cracking right on the grain. I finally threw it away.
I could snap the Sitka of my cello 1/8" thick. Easily.
I was really wondering about the curly redwood of my archtop. It seemed very flimsy. It sounds great. I may put lighter strings on it though. I didn't realize that the 80/20's had more tension than the phosphor bronze. I do think that it feels MUCH stiffer with the Z-poxy on it. Same with the Home Depot Cedar with the shellac and resin coating on it.
I did throw away a belly of local 100 years old ERC barn wood. It cracked even more than the Red Spruce did.
We work with thin wood, and then put over 100 pounds of tension on it. Most of the time it works.
Why be normal?
PostPosted: Sat Jul 01, 2023 11:38 am
First name: Ken
Last Name: Nagy
City: Goodrich
I just opened up the plans I bought off Pat Foster. A real blueprint from Guitarmaker's Connection. Cool.It is for a D-28, but I don't know what I will do with the trim yet. The plan doesn't even have a truss rod, but a t bar, with instructions to build in back bow that the string tension will straighten out.
Why be normal?
PostPosted: Sun Jul 02, 2023 7:48 am
that is the same plan as stew mac drawn by Dam MacRostie
its a decent plan. Understand that martin didn't have a blue print for the guitar. They used fixtures. The first print made was for the neck block drawn by Dick Boak in around 1979. The plan you have was contracted by martin to use with the kits they started selling from GMC. You won't go wrong with this one. Dan did a good job.
the guitar changed in 1939 with the rear shifted bracing , added popsicle brace and the narrower neck. I think the brace angle also changed along with the smaller neck block.
when you start building don't make a lot of changes from guitar A to B keep them simple and notice the changes.
Users browsing this forum: No registered users and 43 guests
