It is currently Wed Aug 20, 2025 5:48 am
 Post subject: Idiot!!!!!!!!!!!
PostPosted: Sun Oct 15, 2023 10:25 am
Really not much more I can say.
 Post subject: Re: Idiot!!!!!!!!!!!
PostPosted: Sun Oct 15, 2023 10:27 am
Welcome to the club!
These users thanked the author Pat Foster for the post: jfmckenna (Sun Oct 15, 2023 10:33 am)
PostPosted: Sun Oct 15, 2023 10:40 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Been there.
Sent from my SM-G973U using Tapatalk
Tony Thatcher
Bozeman, Montana
PostPosted: Sun Oct 15, 2023 10:43 am
First name: Brad
Last Name: Combs
Good thing it’s ebony! :)
These users thanked the author bcombs510 for the post (total 2): Bryan Bear (Mon Oct 16, 2023 12:57 pm) • jfmckenna (Sun Oct 15, 2023 11:38 am)
PostPosted: Sun Oct 15, 2023 11:33 am
Comes with a free t-shirt!
These users thanked the author meddlingfool for the post: jfmckenna (Sun Oct 15, 2023 11:38 am)
PostPosted: Sun Oct 15, 2023 11:48 am
Last Name: Russell
State: Michigan USA
Simple fix...
Just move the side dots and no one will ever know.... idunno
Cheers,
Bob
These users thanked the author RusRob for the post: jfmckenna (Sun Oct 15, 2023 6:03 pm)
PostPosted: Sun Oct 15, 2023 11:59 am
Last Name: Sollod
Stuff happens…. There so many way to make a mistake. gaah At least the fingerboard is ebony. You may been able fix it with dust and glue…
www.swiftcreekguitars.com
PostPosted: Sun Oct 15, 2023 12:55 pm
I haven't done that one before, but there's not enough room to list all my mistakes.
These users thanked the author Chris Pile for the post: jfmckenna (Sun Oct 15, 2023 6:03 pm)
PostPosted: Sun Oct 15, 2023 12:56 pm
Early on in my building, when this happened I tried filling the holes with ebony dust and epoxy, but the fill was too glossy. Instead, I inlayed ebony strips between the frets, just wide enough to cover the holes. They were indetectible.
I haven't repeated this problem with the classicals I build now, but I did make an 11-fret neck.
These users thanked the author Pat Foster for the post: Bryan Bear (Mon Oct 16, 2023 12:57 pm)
PostPosted: Sun Oct 15, 2023 1:24 pm
Oops!!
PostPosted: Sun Oct 15, 2023 2:07 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I feel your pain, regularly.
I just feathered an X-Brace to zero- "oops" wrong brace.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: jfmckenna (Sun Oct 15, 2023 6:03 pm)
PostPosted: Sun Oct 15, 2023 2:51 pm
I feel your pain, did that on a mandolin. After lots of expletives I just routed out the piece ebony with the wrong dots between the frets and inlayed a new flat piece then drilled for dots in the correct location. A bit of a PITA but not the hardest thing I've had to fix. Now I take a white pencil and mark the fret numbers on the fret board before I start inlaying anything including side dots.
These users thanked the author SteveSmith for the post: Kbore (Sun Oct 15, 2023 3:27 pm)
PostPosted: Sun Oct 15, 2023 3:37 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I was installing side marker dots working my way up the fretboard starting at the nut. Right after installing my double side dot markers at the 12th fret I realized I had put them at the 9th fret. The 9th fret was marked by two inlays in the fretboard so I spaced out and thought I was at the 12th fret. Argh. That fretboard was bound with curly koa so no way to fix it invisibly like you can do with ebony. So, that guitar has three side marker dots at the 12th fret.
PostPosted: Sun Oct 15, 2023 6:06 pm
I thought I'd try the easy way out first. It's close but the dust and black CA is probably not going to cut it. Wood inlay is probably a better fix any way.
These users thanked the author jfmckenna for the post (total 3): Bryan Bear (Mon Oct 16, 2023 12:59 pm) • bcombs510 (Sun Oct 15, 2023 6:26 pm) • Chris Pile (Sun Oct 15, 2023 6:08 pm)
PostPosted: Sun Oct 15, 2023 7:28 pm
First name: Karl
Last Name: Borum
I had to go to the "before" picture just to make sure.
From where I'm setting it looks 98%. Cut a grain line or two.....
Measure Twice,
Karl Borum
PostPosted: Sun Oct 15, 2023 7:30 pm
That's a good idea I will try that tomorrow.
PostPosted: Sun Oct 15, 2023 8:28 pm
First name: David
City: Napa
Zip/Postal Code: 94558
I know a guy who this happened to once. I don't understand how a 14 fret can end up being a 12,13,14,15th lol
PostPosted: Mon Oct 16, 2023 1:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That repair probably doesn't look as bad as you think it does. Remember that there will be strings traversing the board and that will disguise the repair further. Put some oil on there and see how much it stands out. If you can't live with it, go ahead and put in some fret to fret patches.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Kbore (Mon Oct 16, 2023 4:26 pm)
PostPosted: Mon Oct 16, 2023 1:28 pm
Fret to fret patches will wear better and be indistinguishable from the rest of the board if well done. It looks like a "High End" guitar and might be worth the extra effort.
These users thanked the author Clay S. for the post (total 2): Kbore (Mon Oct 16, 2023 4:26 pm) • Bryan Bear (Mon Oct 16, 2023 2:51 pm)
