It is currently Mon Jun 16, 2025 3:30 am
PostPosted: Mon Oct 14, 2024 2:56 pm
Salutations.
The spring pin that holds the gear to the elevating shaft of my drum sander has snapped, allowing the shaft to spin freely in the gear rendering it useless. I have managed to remove the remnants of the old pin from both shaft and gear and have a clear pathway to knock in a new spring pin and resurrect my drum sander.
My question is, is there some specific benefit from having a hollow spring pin vs a solid core rod such as say the back end of a drill bit? Is there some machinist wisdom I should know about? I’ve found suitable spring pins online and can buy them, but they come in bags of 100 which is 99 more than I need.
Any downside to just using a drill bit or some other type of hardened steel rod?
PostPosted: Mon Oct 14, 2024 3:28 pm
City: U.P.
The roll pin is slightly larger in dia than the hole. So when it is tapped in the compression of the roll holds it in place. It is a very effective fastener for the purpose. Any hardware store or big box builders supply would have a selection. I'd replace it in kind.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: meddlingfool (Mon Oct 14, 2024 3:42 pm)
PostPosted: Mon Oct 14, 2024 4:04 pm
Last Name: Ensor
City: Springfield
State: Missouri
Stick with roll pin unless you plan on penning the solid pin. Otherwise it may work itself out due to the vibration of the machine. And even then I would stick with a roll pin…
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post (total 2): Kbore (Thu Oct 17, 2024 11:55 am) • meddlingfool (Mon Oct 14, 2024 4:55 pm)
PostPosted: Wed Oct 16, 2024 9:39 pm
Spring pin for the win. In house thicknessing returns which beats a 45 minute walk each way to the hobby collective down the road. Pray it lasts until I can upgrade…Image
Thanks for the tips!
These users thanked the author meddlingfool for the post: Kbore (Thu Oct 17, 2024 11:55 am)
