It is currently Sat Jul 19, 2025 1:44 am
PostPosted: Sun Mar 09, 2025 9:02 pm
Last Name: Colbert
City: Anacortes
Ed Bond will not approve but it was fun to do. I’ve been using a full bolt on necks for many years now and wanted to improve my approach. I know what I’m doing is nothing new - it’s pretty hard to have an original idea in the luthier world, still I’m pleased with the outcome.
These users thanked the author Michaeldc for the post (total 6): Durero (Sat Mar 15, 2025 2:18 pm) • Kbore (Fri Mar 14, 2025 1:03 pm) • rbuddy (Mon Mar 10, 2025 9:10 am) • SteveSmith (Mon Mar 10, 2025 8:27 am) • bcombs510 (Mon Mar 10, 2025 4:46 am) • Colin North (Mon Mar 10, 2025 4:12 am)
PostPosted: Sun Mar 09, 2025 10:15 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
My most recent neck joint is the Gore/Gilet bolt on, bolt off. I like it very, very much. You are using good sense, in my book!
These users thanked the author doncaparker for the post: Michaeldc (Mon Mar 10, 2025 6:49 am)
PostPosted: Mon Mar 10, 2025 1:33 am
Lols. The best thing about my approval is that no one anywhere needs it.
These users thanked the author meddlingfool for the post (total 4): Kbore (Fri Mar 14, 2025 1:07 pm) • Robbie_McD (Wed Mar 12, 2025 7:36 am) • bcombs510 (Mon Mar 10, 2025 4:46 am) • Michaeldc (Mon Mar 10, 2025 3:21 am)
PostPosted: Mon Mar 10, 2025 8:58 am
First name: David
City: Napa
Zip/Postal Code: 94558
Nice and clean. I learned about this neck joint in Charles Fox class. You have re inspired me to retry it again. Are you cutting your necks on Cnc? Where did you get the neck router jig?
These users thanked the author dofthesea for the post: Michaeldc (Mon Mar 10, 2025 9:34 am)
PostPosted: Mon Mar 10, 2025 9:42 am
Last Name: Colbert
City: Anacortes
Hi David,
Portions of my necks are cut on my CNC. Everything between the volute and body joint are done by hand allowing for easier customization. I don't have to redraw each neck shaft and generate fresh g-code each time. The neck fixture is my own design and was also cut on my CNC.
Best, M
These users thanked the author Michaeldc for the post: Kbore (Fri Mar 14, 2025 1:08 pm)
PostPosted: Mon Mar 10, 2025 10:04 am
Last Name: Parker
City: Charleston
Michael--
One follow up regarding my first use of the Gore/Gilet bolt on, bolt off neck joint: Next time I build one, I think I will use threaded inserts in the neck extension, rather than T-nuts. Maybe a 6mm T-nut in Australia has a smaller footprint than a 1/4-20 T-nut here in the U.S.A., but I found that the T-nuts made things a bit crowded around the slot for the truss rod.
These users thanked the author doncaparker for the post (total 2): Kbore (Fri Mar 14, 2025 1:08 pm) • Robbie_McD (Wed Mar 12, 2025 7:37 am)
PostPosted: Mon Mar 10, 2025 10:18 am
Last Name: Colbert
City: Anacortes
doncaparker wrote:
Michael--
Don,
I always felt that the neck extension portion of the Gore joint was too husky for my liking and also never fancied threaded inserts. Instead it use a 10-32 t-nut (Brad type) that gets glued in place with some medium CA plus the glue from the fretboard install. The recess is .75” x .0625” with .25” center hole. Drops right in nice and snug. Maybe I’m missing the point on how strong it needs to actually be. I do like Gore’s brass bar insert but don’t own a chisel mortiser and I’m not sure it’s stronger than the barrel bolts I use.
Best, M
These users thanked the author Michaeldc for the post: doncaparker (Mon Mar 10, 2025 11:27 am)
PostPosted: Mon Mar 10, 2025 10:33 am
First name: Brad
Last Name: Combs
Michael,
Would you mind sharing a pic of the underside of the routing jig? I’m assuming the two holes are just to spy on the centerline to sanity check alignment but the pocket is creating the actual alignment on the body?
These users thanked the author bcombs510 for the post: Kbore (Fri Mar 14, 2025 1:10 pm)
PostPosted: Mon Mar 10, 2025 11:30 am
Last Name: Colbert
City: Anacortes
bcombs510 wrote:
Michael,
Brad,
Yes, that’s exactly right. It’s cut from 1/2” pre-fin Europly using 1/4” aluminum rod for the index pins.
M
These users thanked the author Michaeldc for the post (total 3): Durero (Sat Mar 15, 2025 2:20 pm) • Kbore (Fri Mar 14, 2025 1:10 pm) • bcombs510 (Mon Mar 10, 2025 11:52 am)
PostPosted: Mon Mar 10, 2025 11:31 am
Last Name: Parker
City: Charleston
Michaeldc wrote:
doncaparker wrote:
Michael--
Don,
Best, M
I think 10-32 will do fine. I don't think you need as much oomph on the neck extension as you do for the neck tenon.
I bought a used mortiser for around $100. It works fine. There seem to always be a few for sale on Facebook Marketplace. The brass bars are pretty stout!
These users thanked the author doncaparker for the post: Michaeldc (Mon Mar 10, 2025 11:43 am)
PostPosted: Mon Mar 10, 2025 3:58 pm
Last Name: Colbert
City: Anacortes
doncaparker wrote:
Michaeldc wrote:
doncaparker wrote:
Michael--
Don,
Best, M
I’ve used the 10-32s on my last 40 instrument without issue, so I agree they are adequate.
As the a mortiser - I’m sure I could find one though I’m not willing to give up the shop real estate.
Cheers -
These users thanked the author Michaeldc for the post: Kbore (Fri Mar 14, 2025 1:11 pm)
PostPosted: Tue Mar 11, 2025 11:15 am
I like it! I have been using a separate fretboard tenon but have seriously considered going to the tenon incorporated into the neck as you have done.
ImageIMG_6113 by Terence Kennedy, on Flickr
ImageIMG_1889 by Terence Kennedy, on Flickr
Couple of questions, obviously the upper bout has to be exactly coplanar with the neck angle for the fretboard to sit flat. How much movement do you get after string up and at say 6-12 months? If a minor neck reset tweak is needed to maintain proper saddle height is it hard to get the fretboard to sit flat against the upper bout since it’s no longer coplanar. Do you create any drop off in the fretboard extension?
The other thing is I didn’t notice any tenon reinforcements with the Cumpiano barrel nut technique. I had a couple of my early ones crack through the lower nut and always reinforce now.
Nice work!
These users thanked the author Terence Kennedy for the post: Kbore (Fri Mar 14, 2025 1:12 pm)
PostPosted: Tue Mar 11, 2025 11:42 am
Last Name: Colbert
City: Anacortes
Nice work!
Hi Terence,
So far I’ve only needed to adjust the neck angle on one instrument. I had one I built 13yrs ago come in for a checkup and the action was exactly where it was when I built it - 5/64” and 3/64”. I think my design has proven to be very stable.
I’ve never found the need for the added tenon reinforcement. I’ve never had one fail in the 16yrs I’ve been building.
My old design looks quite similar to yours.
M
These users thanked the author Michaeldc for the post (total 2): Kbore (Fri Mar 14, 2025 1:12 pm) • Terence Kennedy (Tue Mar 11, 2025 1:18 pm)
PostPosted: Tue Mar 11, 2025 1:21 pm
Thanks! Did your old design move more under tension than the new? In other words did the new design improve stability?
PostPosted: Tue Mar 11, 2025 1:25 pm
Last Name: Colbert
City: Anacortes
I don’t know - this is my first go with the new design - the old design was rock solid.
These users thanked the author Michaeldc for the post: Durero (Sat Mar 15, 2025 3:09 pm)
PostPosted: Tue Mar 11, 2025 3:12 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Great design.
I really like the routing jig that is long enough for you to check alignment all the way down to the bridge area.
Thanks for the inspiration, and for the very clear illustrations.
These users thanked the author Mark Mc for the post (total 2): Kbore (Fri Mar 14, 2025 1:13 pm) • Michaeldc (Tue Mar 11, 2025 4:46 pm)
