It is currently Thu May 07, 2026 3:18 pm
PostPosted: Mon Aug 04, 2025 6:04 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Any hands-on experience with the Laguna DP:20 which those here may care to convey? It is on the list of potential drill press purchases, along with the Nova Voyager and the Powermatic PM2820EVS. I've been making do with one of the boy's old bench-top drill presses, and it seems like time for an upgrade to a larger 18"-20" swing and speed-select functionality.
And yes - I am already familiar with Laguna's notoriously bad customer service, although at least anecdotally that seems to be changing of late. I have their bench grinder and while no old-school Baldor, it is a respectable tool for my sharpening bench.
PostPosted: Mon Aug 04, 2025 8:13 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have the Voyager drill press and I love it. It’s quiet, infinitely adjustable and has worked perfectly since I got it a few years ago. The only issue is the table deflects a little when I press frets.
I bought the Laguna 12-16 midi lathe a few years ago. It could have been a great tool. It was advertised to turn 16” on the outside for which I bought it. The index pin is next to the shaft on the outside preventing the mounting of a chuck. The extender provided has .009” runout. I’ve been unable to procure an extender without runout. The tool came with the shaft and the tail piece misaligned. The alignment allen screws are undocumented and located inside the pulley housing where they are almost impossible to reach. I probably will never buy another Laguna tool no matter how inviting it looks.
Good luck in your quest.
PostPosted: Mon Aug 04, 2025 8:45 am
First name: David
City: Napa
Zip/Postal Code: 94558
Keep in mind that laguna has the worst customer service, so if you need tech support and or parts your up sheet creek. I wouldn't buy anything from Laguna unless it's their Italian Industrial tools. Which are not made in China.
PostPosted: Mon Aug 04, 2025 11:20 pm
First name: Mark
City: Seattle
I was pretty interested in the Laguna drill press until I watched this video https://www.youtube.com/watch?v=ZvHNlOsu7bI
PostPosted: Tue Aug 05, 2025 7:21 am
First name: Willard
Last Name: Guthrie
City: Cumberland
Re: the review videos, I did view both the contributor's original and follow-up video. While I agree that a panic button seen on a number of tools is a good idea, a kick plate power cut-off seems like a better idea if the primary hazard anticipated is as seen in the video. Getting close enough to the head unit cutoff switch seems problematic, while kicking a foot-level plate for power cutoff seems like it might be lower risk when dodging flying clamps and work pieces.
The safety issue highlighted in the first scene of the follow-up video appears to be more of mental and tool use error on the part of the gentleman 'testing' the tool than any fault with the drill press. Use of a single, light-weight clamp to secure a relatively small work-piece against very large rotational forces seems like a good recipe for the sort of mishap depicted. Further, having the clamp's moving foot and excess shaft above the table runs the risk of potentially trapping the operator's arm and spindle handle against the tool if anything shifts. Finally, multiple clamps distributed as a minimum on both sides of the desired hole location should be used for securing work to the press table where the work will be subject to high rotational forces. Having a piece of tool steel (the bar of the clamp as employed by the video author) whirling about at eye level seems to be the most egregious mental error in the video, and the one most easily addressed. 'If everything goes perfectly, I should be able to make this cut' is not what I want going through my mind before hitting the 'on' switch.
To the best of my knowledge, Taiwan seems to be the location of primary manufacture for the Nova, Powermatic, and Laguna presses (at least based on motor badging) under consideration, although regionally distributed manufacturing is pretty common in that area of the world, with electronics, motors, and mechanical components sourced from around the First Island chain and mainland China. The good news for those of us that would prefer not to bankroll one or more of the global bad actors in that area is that the economic consequences of basing one's economy on IP theft, child labor, and low and mid-tech manufacturing/low-cost final assembly for global export has come home to roost for at least one of the major players in the region with skyrocketing labor costs and endemic recession. Absent large investments in sunk infrastructure by large multinationals, we should be seeing a growing number of choices for sourcing of manufactured goods over the next decade. While I doubt we see a new/old Powermatic foundry in Tennessee, we may well see one in Mexico or Columbia as we re-shore. Coming in the door with this realignment of trade and re-shoring is global competition for capital, so we should expect interest rates to remain higher than what we might wish.
In the meantime, it seems like we have relatively limited choices, so really Laguna and Nova for 'smart' presses and Powermatic for EVS 'old school' presses. Not wild about touch-screen tech, but seems like that is the direction of march for machines. In years past, even a 100 year old machine could be made as new with a little work; not sure how we will replace fragile displays or aging PCBs 20 or so years from now.
These users thanked the author Woodie G for the post: Kbore (Tue Aug 12, 2025 4:56 pm)
PostPosted: Tue Aug 05, 2025 10:43 am
State: West Somerset
Country: UK
A bit sideways to your question but I have been using a Jet drill press (JDP-13) for years and have found it excellent. It is not a floor mount but has plenty of vertical travel. It is fairly old fashioned with cast iron and multiple pulleys for speed change.
Assuming Jet is available in the US I would recommend a look at them.
Cheers Dave
PostPosted: Tue Aug 05, 2025 2:58 pm
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Love my Nova Voyager. It replaced a large Rigid machine.
PostPosted: Thu Aug 07, 2025 7:31 am
City: U.P.
I can't be too specific to your question but offer some general comments.
I had a Delta (early 1990's) when they first started to off shore and it was junk. There was so much slop in the quill that the Morse taper chuck would fall out regularly from vibration. Gave it away.
Replaced it around 2005 with a Powermatic 2800. Mechanical variable speed adjust. It's an OK drill press but I'd call it medium to light duty. There was too much runout in the chuck so I replaced it with a Jacob's and it helped with precision. Powermatic stresses "woodworking" with only a mention of "other materials". If you are only drilling wood and occasional metal they are OK.
What I like about most older machines is the split quill housing that allows you to lock the quill or adjust fit of the housing to the quill. If there is one thing I would look for in a drill press it is that adjustment. Most recent drill presses only have a crude screw that is supposed to snug up the quill/housing fit and IMO they aren't worth playing with, all they do is add friction to the quill and make it appear more snug, they don't change bore dia at all.
I've been looking at the Nova which looks like it has a split quill housing to lock the quill or snug it up properly. And it has a ton of handy features and gets great reviews. Their ads mention drilling a variety of metals in addition to wood. That's where I'm putting my money at the next change up.
Lots of good deals on older machines if you can live w/o the electronic features. Just look for an adjustable quill housing, with no wobble in the bearings and take a piece of 1/2" drill rod and a dial indicator to check them out.
Let us know what you buy and how you like it.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Durero (Thu Aug 07, 2025 2:10 pm)
PostPosted: Mon Aug 11, 2025 9:10 am
I bought my Steel City 17" around 15 years ago when they were still in business. Split head design and 6" quill stroke. Almost no runout. Looks like somebody makes a cheap version nowadays with only the name being the same. No split head and short quill stroke. If you can pick up a used one, it's a great press.
PostPosted: Mon Aug 11, 2025 4:31 pm
First name: Mark
City: Seattle
Looks like there is another touch screen drill press coming out, from Harvey Woodworking. It is not on the Harvey web site, but there is a video here: https://www.bing.com/videos/search?q=ha ... &FORM=VIRE
I have no experience with Harvey's power tools, but they took over Bridge City Tools a few years ago. I bought one of their Kerf Makers and it is very nicely made.
PostPosted: Wed Aug 13, 2025 12:52 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Thanks all for the feedback! Very welcome indeed.
It seems like I will delay any purchase for a bit, as the boys apparently picked up a DP:20 from the local Woodcraft this past weekend. I'll give them a few weeks to get a feel for how it stacks up against other offerings. I suspect it will get an Albrecht, so will leave me with another chance to talk myself into no new shoes for a few months - they are really quite beautiful as well as expensive things... the chuck of course. Worst case is that I will pick up Greenridge's old Delta 16-1/2", but I really want that 20" swing if possible. Supposed to go over to Germantown this weekend to refret a Walker... so hope to fiddle a bit with the new drill press in between hammering on a 'VEI'... :)
PostPosted: Sun Aug 24, 2025 8:04 am
First name: Willard
Last Name: Guthrie
City: Cumberland
I've had a couple days in the Greenridge shop with the DP:20, but did not really get a chance to do much beyond making up a replacement bridge for a Gibson Southerner Jumbo and some jig and fixture fabrication work, and that went well. I'll likely go back down to Germantown again next weekend to mill out a bunch of bench parts, to include some deep mortises. For now, I am leaning heavily towards the Laguna, but want to get through some work that will stress the machine beyond drilling holes for bridge pins or index pins before committing.
The boys have kitted out their DP:20 with a Llambrich keyless high precision chuck which is very smooth and positive. I found speed resets and use of the reversing feature became second nature once I got over mashing the big red 'Emergency Stop' mushroom button in lieu of the intended 'on/off' touchscreen button. After a little mental re-programming, things went well. The usual practice in that shop is to provide a tool set proximate to each machine for basic reference, use, maintenance, and setup, so the drill press has hex keys, quill/spindle wedge, keyed chuck w/spindle for small bits, tap charts, and the usual reference material available as shown in the attached pics.
Like everything else in the Land of the Giants, the DP:20 got the same 5" shop-made 2x4 and plywood riser that the bandsaw and other machines have received. That proved to be no real obstacle for use with 6" quill stroke and no need to directly access the top of the press for speed changes. Did I mention how quiet the machine was compared to other presses? I got a chance to play with the Powermatic 20" EVS press last week and it was astoundingly loud compared to the Nova Viking in one of the local maker spaces. The PM is much closer to those machine shop gear-head presses and mill/drill units than the still relatively noisy 12 and 16 speed traditional drill presses I have been using. Likewise, while the guided menu function for speed/material selection programmed into the Nova Viking and Voyager would be handy for someone less familiar with best speeds for various operations and bits, that was pretty well drummed into me during my early days at Greenridge (Forstner bit replacement due to overheating gets expensive!!!). I did like the Viking, and it is the quietest drill press of the three I am considering, but getting that extra couple inches of swing is still of interest.
The pics attached give some idea of scale (with riser bIock base installed) - both gentlemen in the shots are 6' or over. I wrapped up the Walker refret and got a chance to assist in milling out 30+ BRW bridge blanks and a half dozen head plates from $200 worth of relatively small cutoff blocks... these were an eBay find that should keep that shop in replacement bridges for another year or so. FWIW, I believe those blanks are suitably marked up for material and milling costs. Retailer's Rule of Thumb: price for replacement/replenishment versus cost to acquire/put in stock.
Best for last: with the Federal and state budget cuts hitting in the new fiscal year, I have decided to start my transition to retirement earlier than originally planned and move to telemedicine. This allows me to regain some of that 50 hours or so of time spent in the office/commuting while still seeing many of my long-time patients (the very best part of a clinical practice). My new schedule will allow me to spend more time with grand-babies, working out/riding, writing, and - very important - in the shop. With that transition comes decision time on adding a separate shop building... while I would lose some of my cherished backyard space, my basement is currently office, sewing room, and preferred writing space. Decisions... they are the very devil!
These users thanked the author Woodie G for the post: Durero (Sun Aug 24, 2025 1:17 pm)
PostPosted: Mon Sep 15, 2025 5:08 pm
Last Name: Hemsey
City: Seattle
Zip/Postal Code: 98104
I’ve had some time on the DP 20. Solid, smooth, and the variable speed is nice to have. Fit and finish are good, though not quite on par with Powermatic. If you’re already used to Laguna’s quirks, it’s a pretty capable press. Between the three you’re considering, I’d say it comes down to whether you value the Voyager’s tech features or the PM’s heavier build.
PostPosted: Mon Sep 15, 2025 8:24 pm
I know nothing about Lagunas drill presses. I just took a quick look at them online and am not impressed..
Many Years ago I had a horrible experience purchasing a 24" band saw from them.
What I do know from my 50 years of buying, selling and rebuilding woodworking machines is that the best bang for the buck is old (not too old) American Iron.
Facebook marketplace,Craigslist are filled with great deals on Rockwell,Delta, Powermatic, etc. drill presses for short money.
I own a Rockwell drill press that I bought 45 years ago ( new) that has never let me down that I have used constantly-I have seen the same ones for sale in as good condition for around $200-$400.
These users thanked the author Brad Goodman for the post: Kbore (Tue Sep 16, 2025 11:28 am)
PostPosted: Tue Sep 16, 2025 6:50 am
First name: Willard
Last Name: Guthrie
City: Cumberland
This really gets into the engineering side of things, with my knowledge there very much dependent on the discussions I've had with the boys (Aerospace and Computer engineering, respectively). A few notes from my spreadsheets made as I went through my decision-making.
Structure: All of the machines featured very beefy cast iron heads, with net weights of the 18" swing, direct-drive Voyager at 284 lbs, the 20" poly-V belt drive Laguna at 304 lbs, and the 20" gear-driven PM at 336 lbs. My engineers felt the weight differences were primarily due to powertrain choices and swing (18" versus 20"), rather than any significant difference in structural support for motor or quill. In reviews, the only one of the tools that showed any significant deflection of any portion of the structure under load was the Voyager's table, which appeared to be more an issue with the reviewer's assembly process and table clamp lever (remedied by the reviewer with warranty assistance).
Drive Train:
All three presses use a variable speed DC drive; however, the implementations are driven by desired features.
- The Voyager's advanced modes use motor torque and Proportional-Integral-Derivative (PID) controls to implement their chip-breaking cycle during tapping operations, start-under-load options, and other advanced features, so the greater power management system complexity of the DVM scheme and larger motor (1.75 hp at 110V and 2 hp at 220V) requirement for a direct drive system is the price to be paid for accurate. timely instantaneous motor control. Note that the speed range of the Voyager may be menu-set to give access to the 3500-5500 rpm range which may be used for milling operations.
- The PM, without any tech features beyond digital speed read-out has no need to accurately sense motor torque or the sort of control law-driven rates of change in current, etc., so the relative simplicity of grafting a standard DC gear-head metal-working press drive train onto a tool focused on woodworking likely made far more sense to their engineers than a clean-sheet design. Those design decisions also allowed PM to use a smaller motor to achieve desired torque at the chuck with just a 6 amp, 1 hp motor needed.
- The DS:20 is in the middle - the poly V-belt variable pulley system allows fairly accurate and reasonably timely torque sensing using the motor, but without the need to implement a semi-automated tap chip breaking cycle, the more efficient Pulse Width Modulation speed control scheme allowed use of a slightly less powerful motor (1.5 hp versus the Voyager's 1.75/2 hp) for the same available low-rpm torque performance.
Use of technology:
The consensus across the boys and across reviewers that I've found is that the Voyager has the most technically advanced set of control options, with some advanced tapping features (e.g., chip-breaking mode) , speed-at-start options such as low rpm for starting pilot holes/ramp-to-set RPM curve, reversing/auto-reversing, real-time load sensing and display, and a rule-based/heuristics speed-setting application. The DS-20 is more or less in the middle - you get presets, full-range speed control at the twist of a knob, reversing and auto-reversing (useful for tapping and deep hole boring), auto-start, load-sensing and display, etc., but fewer options re: the hole start/stop sequence. The PM is essentially a standard 20th century drill press with digital speed display.
As I mentioned elsewhere, after a couple long weekends with the boy's DS:20, I ordered my own. Mr. Morelli has had a jig-making project running as he sets up production for his latest run of guitars, so a bit of an acid test for the DS:20. In summary, after the first week, Mr. Morelli lamented the lack of physical stops, a friction-based quill lock, and the Delta's other features. At the end of the second week, he was a convert, stating Mr. Hall's 'You don't know...' aphorism applied. My experience was more focused on impacts to my work flow, with some order-of-operations changes and simplification in terms of positioning work.
Had Nova had reasonable delivery time frames on the Voyager (now delayed until late October) AND offered a 20" swing, I may have opted for that press due to the noise level alone. While the DS:20 is quite quiet (above 3000 rpm there is some whine from the poly belt), the Nova is definitely quieter. My chief complaint about the PM was noise (the gearbox is really, really loud at anything over 1500 RPM) and lack of reversing, with some minor concern about the two-step process needed to change speed ranges. As to origins, all of the presses seem to be largely manufactured in Taiwan, with Nova's Teknatool manufacturer a bit coy as to actual content by country.
These users thanked the author Woodie G for the post: Durero (Tue Sep 16, 2025 4:03 pm)
PostPosted: Tue Sep 16, 2025 3:43 pm
Good and faithful servant…
Don’t know why anyone would spend thousands of dollars for a machine that couldn’t do anything more than this machine - drill accurate holes…
These users thanked the author Brad Goodman for the post: Kbore (Mon Sep 29, 2025 11:31 am)
PostPosted: Tue Sep 16, 2025 7:05 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
So I suspect there are those here that only use dial calipers that find those of us using digital calipers an anathema. My view is they don't know what they are missing in terms of rational work flow. I have an old-school machinist friend that is brilliant with anything metal, and resisted any type of automation - even digital measuring systems until a year or so back. A mill with three axis measuring system and digital management was given into his care and the owner extracted a promise that my friend would at least dabble. After a week, he declared it asinine and useless froufrou on an otherwise good tool. After two weeks, he was on the fence with regard to value, and a month later he was a convert. 'Digital just works' he said. I love analog, but wanted relative zeros, and - as a person of rather limited height, the 'twirl a dial to set speed' rather than wrestle multiple belts for speed changes is non-negotiable. others may find digital speed and torque management an affectation - but at this point in my life I refuse to be a slave to either tradition or fashion.
Two aphorisms: YDKWYDNUYKI and never say never. ;-)
These users thanked the author Woodie G for the post: Durero (Sat Nov 15, 2025 2:22 pm)
PostPosted: Tue Sep 16, 2025 7:20 pm
Last Name: Gramann
State: VA
I didn’t trust digital measuring tools until I took one (a cheap one) apart and figured out how it worked. Once I understood the mechanism, I was happy. I put a digital dial gauge on one of my thickness gauges. The only thing wrong with it is that the LCD is hard to read at an angle. Of course, that means I usually use the mechanical one.
PostPosted: Tue Oct 07, 2025 12:40 am
First name: Thomas
Last Name: T
I’m extremely happy with my Nova DVR. I can’t imagine using an old school drill press again.
PostPosted: Sat Nov 15, 2025 1:10 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I just picked up a used Nova Viking 16" benchtop drill press for half off the retail price. Gosh, it's nice! Quiet, knob controlled variable speed from 100 to over 5,000 rpm, electronic depth stop, and the runout on the stock chuck (measured on a chucked bit 1" away from the chuck) is only 0.001". It will be a great addition to the shop.
These users thanked the author doncaparker for the post: Kbore (Sun Nov 16, 2025 5:51 pm)
PostPosted: Sun Nov 16, 2025 8:32 am
First name: Willard
Last Name: Guthrie
City: Cumberland
I continue to see what are in reality indefinite backlogs for Nova drill presses from Advanced Machinery and other reputable vendors, so finding a bargain on a used Viking is a lovely bit of luck. I wish you success with your future digital drill press-enabled projects, and hope for a full review from a builder's perspective once you've had a chance to wring out the machine.
My press is still sitting crated in the garage, awaiting next week's visit from the Maryland continent to address the lift with chain hoist and testosterone. The real question is whether I can get them to stay long enough to run another 220V line for a dust collector... maybe my lemon bars would do the trick... bribery with baked goods?
One other thing... most of the 5/8" hand-tightened chucks need a minimum of a .100" bit diameter to tighten, so I exchanged my 5/8" for a 1/2" chuck, which can handle a .030" bit without issue. While the Albrecht and Llambrich chucks are rather expensive, they are without peer in terms of smoothness, absence of run-out, and grip. I was a little hesitant to mill out some 6" blast gate parts on the boy's press using a circle cutter and the hand-tight chuck a few weeks back, but absolutely no issues keeping the bit in place. Good luck with your machine, Mr. Parker.
These users thanked the author Woodie G for the post (total 2): Kbore (Sun Nov 16, 2025 5:52 pm) • doncaparker (Sun Nov 16, 2025 4:08 pm)
PostPosted: Sun Nov 16, 2025 10:01 am
Last Name: Gramann
State: VA
This experience goes back probably 50 years before I knew anything and way before I ever considered building guitars. I learned about Morse tapers attempting to use a fly cutter in a drill press. The imbalance of the fly cutter wiggled the chuck shaft out. Fortunately, only the workpiece was damaged. I don’t remember what I was trying to make, but I remember the chuck and cutter dropping. I’ve been wary ever since about chucking something not balanced into a drill press.
These users thanked the author bobgramann for the post: Kbore (Sun Nov 16, 2025 5:53 pm)
PostPosted: Sun Nov 16, 2025 4:23 pm
Last Name: Parker
City: Charleston
Much appreciated, and good luck with persuading your crew to do some heavy lifting. Food is a good choice.
This Viking is the most recent of my favorite type of tool acquisition: picking the bones of someone else’s exit from an endeavor (a maker business, hobbyist guitar maker, general woodworker, etc.). It’s how I got my CNC, my drum sander, and several other things for which I would not want to pay retail. Facebook may be a heavy contributor to the ills of the world, but if there are silver linings, Marketplace is one of them. People get rid of some pretty useful things on there, often at “please haul this away” prices.
These users thanked the author doncaparker for the post: Kbore (Sun Nov 16, 2025 5:53 pm)
Users browsing this forum: Freeman, Ken Lewis and 13 guests
