It is currently Fri May 08, 2026 2:10 am
PostPosted: Sun Jan 28, 2007 8:49 am
So I bend my first sides and I still have much to learn. I will give you the background and maybe a few can chime in give me a few pointers...
Wood.
Granadillo
.080 thick
Setup
Doolin Style Bender
One blanket
Temp Probe
"Router Speed control" temp control
SJ Shape
Foil to wrap wood
First side everything seemed to go well however when I took the side out of the bender it seemd there was a crack on inside the waist. The crack was not all the way through and looked like the grain was lifting. I put a little glue and clamped it back in the side bender overnight. I look ok in the morning but it still feels like there is a small flat on the outside where the crack is. I guess I just rushed things....
The bend the second side today. This time I took much more time when bending. When I bent the waist I turned the cauls knob bolts 1/2 turn every 30 seconds. It seemed to help keep things good. When I took the side out of the bender the spring back was better and the shape was good with no cracks. However, it seems that there is a dark discoloration in the waist area.
How much water do you use? How much is a spritz?!?
How do you prevent discoloration?
Where do you put the temp probe to get a good temp reading? I think I was getting a bad temp reading which made me think the temp was under 300 but was actually over.
How long do most people take bending a side?
I think I am going to use this side set as my sacraficial set to dummy proof my processes but need to figure out what I am doing wrong to make sure then next set isn't messed up.
Thanks!Brad Way39110.7019791667
Brad
Avon, OH
PostPosted: Sun Jan 28, 2007 10:45 am
Hi Brad,
First of all, take comfort in the fact that Granidillo is one of the most
difficult woods to bend. IMO   So, it's only gonna get better.
When I put mine in foil they are pretty wet. I spritz them untill they are
soaked then let them drip standing up, like for just a minute. Then into
the foil and onto the bender.
I don't know why the grain lifted on the first side but it can be fixed.
There is a thread on that on the forum right now.
The Granidillo is very oily and the black stain is probably the oil cooking
out. When you took so much time to bend the second side it was worse
because it cooked longer.
About temp. I turn my control up about 3/4 of the way then listen for the
water sizzleing, then crank it down. From the time it sizzles untill it's all
cranked down is maybe 4 min.
Get some cheap material to practice on, and before long it'll all be good!
Hope this helps
Long
PostPosted: Sun Jan 28, 2007 10:46 am
Last Name: Abercrombie
[QUOTE=Brad Way]
Brad-
I've never bent grenadillo, so I can't offer much good advice. Hopefully more expert voices will chime in- some of the participants here have bent many hundreds of sides.
I usually try to bend some offcuts from the sides (if there are any) to get an idea of problems to come, but it's never real predictable for me.
re: discolorations- Is it a burn-type mark, or just resins from the wood that have exuded during bending? If it is burning, I'd say that you need more water or shorter bending time. Going too slowly can end up 'baking the wood' and actually make cracking more likely.
I usually take 'a few minutes' (ie 2-3?) to bend a side once things heat up.
I usually just stand the side in a bucket of water and slop some water on the wood with a cloth till it's wet, lift and let it drain, then wrap in foil. Once the wood is in foil it's a bit tricky to see what's happening with steam production. I keep a spray bottle of water handy and shoot some on the foil or the slats just to get an idea of how hot things are- this is also a way to cool things down as well.
Some very resinous woods (like EI Rosewood) need very little water and seem to bend with the oils in the wood easing the process.
Fun, ain't it??
PostPosted: Sun Jan 28, 2007 10:56 am
Brad, I ust the technique that John Hall shared here on the OLF some time back. I take a piece of craft paper (that bworn paper like you wrap packages in) and make a piece big enough to cover each side of the piece I'm bending. Then just soak the paper under the faucet till it's nice and wet. Lay one piece of the wet paper on each side of the side wood and stick it between the slats along with the blanket.
Once it gets heated up you can see the steam coming out and it's time to bend. I don't go particularly slow with the bend unless it is a really brittle wood. Couple of minutes to get everything bent and then turn off the heat. Once the side cools back down to room temp I reheat it one more time and it seems to reduce the springback nicely.
Oh yeah, I also use 2 blankets so it gets hot really fast. Not necessary, but I like it just fine.
PostPosted: Sun Jan 28, 2007 12:04 pm
Hesh...my stack from top to bottom is....
Spring Steel Slat
blanket
wood in foil
Spring Steel Slat
I think one thing that would help is to use a few metal spring clamps to clamp the slats and wood together. If I could keep the blanket and wood in good contact then I think it will bend better. Maybe Granadillo wasn't the best to start with. I was once told that mistakes happen from a lack of experience and experience comes from making mistakes.
By the way I just watched the Taylor Factory Friday video of their benders. Amazing...no water...minimal spring back...2 sides at once...and quick.
Thanks for the advice.
Brad
Avon, OH
PostPosted: Sun Jan 28, 2007 12:10 pm
here are the instructions for bending .
http://www.bluescreekguitars.com/tutorial10.php
   I am sure this can help. I have been using this technique for years. I bent 200 sets last year.
john hall
