I think for redwood, going for a predetermined thickness is not such a good idea. If you know how thick you want to make a cedar or spruce top, you could make up a top and the flex it in you hands. Then make the redwood top and compare the stiffness to the other top. Keep making it thinner until it is about the same stiffness as the cedar or spruce top. Your hand flexing is probably a very good read on stiffness. If you aren't comfortable with that, you could also make a jig to measure deflection.
_________________ "An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered." G. K. Chesterton.
