It is currently Fri May 08, 2026 2:12 am
PostPosted: Thu Apr 12, 2007 4:47 pm
The only grain filler I've tried is the water based from stewmac. That
prompted me to go back to spraying sanding more lacquer to level. Is there
a grain filler some one is using that works well without a lot of mixing or
prep. The stewmac stuff didn't seem to do much at all.
PostPosted: Fri Apr 13, 2007 2:15 am
I like traditional paste wood pore filler (either water-based or oil-based) mixed with stains to add some color to the wood. Behlen's Pore-o-Pac is a good brand.
PostPosted: Fri Apr 13, 2007 2:18 am
I'll second the use of epoxies. I use System Three but from what I hear Z-Poxy is just as good if not better and it's cheaper too. Z-Poxy is also more forgiving in mixing ratios than System III.
Just be sure to let it cure completely before sanding, at least a good 24 hours. Even more if you can wait that long. A hot and dry environment to cure will help as well.
