It is currently Fri May 08, 2026 3:00 pm
PostPosted: Tue Mar 15, 2005 7:51 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Am I correct believing that radii for the following are top 28'- back 15':
L-00
00
000
OM
What are the correct radii for small jumbo and jumbo
PostPosted: Tue Mar 15, 2005 8:31 pm
Bob,
I've only got the two sizes of dish, 15' and 25' so that's what everything gets, hopefully the right way round! I don't think that it really matters as long as the slight domes are introduced. Some people use a dome only on the lower bout section, but this gets all too complicated for me I like to keep things simple. If 28' and 15' are the dishes you've got then they'll be just fine for all your needs.
PostPosted: Wed Mar 16, 2005 1:58 am
Bob I use a bit flatter than Colin 20' back, 25' D-models and 28' OM-SJ top, I think any thing in the 15'-20' back and 25'-30' top range will impart enough add section modulus to give the strength need. i am considering a 15' on my new SJ's backs just for apperance.
PostPosted: Wed Mar 16, 2005 6:55 am
Last Name: Johnson
State: CO.
Thanks very much for the info.
PostPosted: Wed Mar 16, 2005 7:13 am
Bob, I use 15' and 28' for everything. It's worked out well so far.
PostPosted: Wed Mar 16, 2005 3:00 pm
State: ON
I also use 15' and 28'. Has worked well for me.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
