It is currently Thu Aug 21, 2025 7:10 am
PostPosted: Wed Jan 02, 2008 10:38 am
I've gotten some advice on plans for a parlor, but most seem to be small
Martin 5 size or slot headed and 12 fret. I'd like to go a bit bigger (ub 13
1/8" and lb 9 1/8") like a Larrivee with a 14 to body neck. So far I haven't
come across a plan that fills the bill. Thanks
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Jan 02, 2008 10:46 am
I would second that.
Any leads would be appreciated.
PostPosted: Wed Jan 02, 2008 1:21 pm
Check out this old thread. You can download pdf or autocad files of a tracing of a 1937 0-18 14-fret. The links are still active. If you don't have cad software, you can print out the pdf on letter size sheets to tape together for a full size pattern. I don't have any of the bracing info.
link
You might also look on the Unofficial Martin Guitar Forum, http://www.umgf.com and stickied to the top of the Technical section is a discussion where folks have posted pics of their Martins with a light on the inside so you can see the outline of the braces. I think there were some 0-size 14-fretters in there. Not exact, but should give you an idea.
PostPosted: Wed Jan 02, 2008 4:02 pm
Great, thanks!
Rich Smith
Issaquah, WA
