It is currently Tue May 12, 2026 7:56 am
PostPosted: Mon Apr 04, 2005 7:20 am
Hello Everyone,
My jointer table has some rust spots on it, and a little bit of black discoloration. How can I clean it off, an what do I do to protect it in the future?
Thank you.
JeffJeff Doty38446.6821412037
PostPosted: Mon Apr 04, 2005 8:25 am
Naval Jelly, steel wool and elbow grease.
Mist it with wd 40 to keep it from happening again. Wipe it down with a
little Naptha on a rag befoe you use it and the oil won't get on your wood.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Mon Apr 04, 2005 8:31 am
pin a scotch bright pad under your RO sander and it will make quick work of cleaning up the bulk of the table. I read this in FWW and it is a very good trick.
PostPosted: Mon Apr 04, 2005 8:41 am
I use Johnson's paste floor wax on mine to keep the rust from coming back. Makes things slide across the table a little easier too.
PostPosted: Mon Apr 04, 2005 9:36 am
When we moved two years ago, the moving truck was put on a train and sent across the country. Well, the trailer of the truck had some sort of leak because we had a lot of things that were water damaged. Including my table saw and jointer. So I just put a 120 sheet on my ro sander and went to town. Making sure that I didn't chase one little spot but worked the whole area as to keep it all level and true. Worked very well. Then I slathered it with Johnson's paste wax and as said before, things slide much easier. I rewax about once a month now.
PostPosted: Mon Apr 04, 2005 1:14 pm
I have always just used a random orbital sander with fine grit to buff out the spots of rust and discoloration then follow with paste wax in very small amounts. This will not alter the flatness of the jointer bed enough to effect the joints straightness.
Hope this helps! Tom
PostPosted: Mon Apr 04, 2005 2:53 pm
First name: Scott
Last Name: Thompson
I've just startd using TopCote. I'm very pleased with it so far. It works well and doesn't stain the wood.
Scott Thompson
Port Townsend,WA
-Billy Bragg
