It is currently Thu Sep 18, 2025 4:33 am
PostPosted: Wed Apr 27, 2005 1:34 am
I am thinking of purchasing this kit. It looks like a good value, and includes Robbie O'Briens DVD.
What do you think of the quality of materials? This will be my second guitar and I am now after tone, clarity, and volume.
Doug Ubele
Guitars...One's too many...Twenty is not enough.
PostPosted: Wed Apr 27, 2005 1:52 am
I think its a great choice for a 2nd guitar - so is building from scratch. I do however think that "going after tone, clarity, and volume" will be a bigger challenge than building a structurally sound instrument.
PostPosted: Wed Apr 27, 2005 6:19 am
Doug,
That's the same set I bought to build my first guitar. It's a great kit you can't go wrong with. The fact that it comes with Robbie's DVD makes it an even better deal. I wish I had his DVD on my 1st couple guitars.
Cheers!
PostPosted: Wed Apr 27, 2005 7:01 am
I just bought it. This is too good of a value to pass up. I looked at the bill of materials and was going to purchase a lot of them separately.
I e-mailed Robbie and he helped me out with the contents. It sounds like a different approach than Cumpiano.
I am hoping to mix the 2 approaches to the most efficient.....if that is possible.
Doug Ubele
PostPosted: Fri Apr 29, 2005 1:43 am
Doug,
You can't go wrong with the LMI kit. It is a great value. I built my first guitar years ago using their classical kit and i sure wish it had my DVD back then!! I built using books and other resource material. I have changed many methods since then and I show them in the dvd. I expect that you will compare my method with others you already know and then come up with a way that works best for you. This is the beauty of it. Everyone has their own way of arriving at the same goal.
As I mention in the dvd the materials in the LMI kit are quality! You can build a top notch guitar using their kit. It is only a box of lumber and I am not sure it should even be called a kit cause you are building from "scratch"
good luck with the build and let me know what you think of the DVD.
