It is currently Thu Sep 18, 2025 12:06 am
PostPosted: Mon Apr 25, 2005 1:56 pm
First name: R
Last Name: Coates
City: Selma
Well, here goes. #4 is on the bench and the B/S are bubinga. Everything is going great when bending the sides I crack them. Both of them. In the same spot. (I always try to leave my sides as thick as possible)
Ok, not so bad it's a small crack I fill with CA and continue the bend. When done I measure and I see that after I contour my sides the crack will be cut/planed away. (it's near the upper bout right on the curve at theback of the guitar)
Then I notice, the other side with the same crack is at the upper bout right at the curve, but on the front of the guitar.
Yep you guessed it I bent one side inside out...
Well after the requisit cursing and then thinking " well it's tight grained and figued so maybe no one will notice" I decided I need to buy another set of sides... @#&%?
Anyone have an idea who's gonna have the best price? They are the mottled bees wing pattern.
Ronn
PostPosted: Mon Apr 25, 2005 2:13 pm
before you give up on it, try to reheat, straighten, and rebend.
oh, forgot to add thet you know doubt have excellent company here in the raoob!!crazymanmichael38467.9740740741
PostPosted: Mon Apr 25, 2005 2:49 pm
Yep, been there done that. I rebent a oregon myrtle side set back straight by setting it on a concrete floor and wetting it, then putting the heating blanket on it. I straightened it out, then rebent. I had some flat spots, but just barely, and I saved a nice set. Give it try! You have NOTHING to lose.
PostPosted: Mon Apr 25, 2005 3:09 pm
First name: R
Last Name: Coates
City: Selma
Good idea guys maybe I'll give it a shot tomorrow.
PostPosted: Tue Apr 26, 2005 4:26 am
from the title of this thread I thought you were all talking about me
again....
PostPosted: Tue Apr 26, 2005 5:06 am
The crack could have been a stress fracture already there. Let me know if rebending it doesn't work out. I just bought a board with some nice beeswing in it. Not sure 100% if I have enough extra for a spare set of sides, but I can look.
PostPosted: Wed Apr 27, 2005 1:43 pm
First name: R
Last Name: Coates
City: Selma
Thnx Don will do.
PostPosted: Thu Apr 28, 2005 12:29 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I have rebent side using blankets and didn't straighten out just went slow and did waist and then bouts like normal, didn't have a problem. I normally bend having sides pretty much as thin as possible and almost if not at final thickness. Rebend way I do, is akward but pretty easy.
PostPosted: Sat Apr 30, 2005 7:39 am
First name: R
Last Name: Coates
City: Selma
I tried to rebend it. The crack gave me fits and I eventually ended up scorching it. So I just ordered a new set from LMI. I'll sand these down a lot thinner before bending them. First ones I left at 3mm.
I see a lot of Bubinga rosettes in my future...
Thnx all
RonnRCoates38472.694525463
PostPosted: Sat Apr 30, 2005 9:39 am
[QUOTE=RCoates] I tried to rebend it. The crack gave me fits and I eventually ended up scorching it. So I just ordered a new set from LMI. I'll sand these down a lot thinner before bending them. First ones I left at 3mm.
Thnx all
Ronn[/QUOTE]
Ron, you can always cut them up for binding. I occasionally buy up cheap sets online with no intention of using them for anything but that purpose.
