It is currently Mon Sep 15, 2025 8:42 am
PostPosted: Wed Mar 15, 2006 8:02 am
Very clever jig Terence, thanks for sharing this brilliant idea!
PostPosted: Wed Mar 15, 2006 8:23 am
love the idea! Thanks for sharing!!
PostPosted: Wed Mar 15, 2006 8:42 am
Very handy!
My method is not nearly so hi-tech. I use a spot of superglue to temporarily patch a popsicle stick at the nut location on the neck (perpendicular to the neck's width). I put the neck on my drill-press table popsicle-side-down. The popsicle stick lifts the headstock-end of the neck up just enough that a few passes with a Wagner Safe-T-Planer gives a perfect taper. I pop the popsickle stick off with a chisel, clean it up with two or three passes of a block plane, and the neck is tapered.
Your way is much cooler.
PostPosted: Wed Mar 15, 2006 8:54 am
My method is similar to Kelby's except I have a tapered board with a sort of tenon that runs down the center of it and fits into the neck's truss rod slot. I also use a Safe-T-planer on the drill press for the cutter.
PostPosted: Wed Mar 15, 2006 12:51 pm
Very cool jig Terry !
PostPosted: Wed Mar 15, 2006 12:55 pm
Anyone have a cool jig for shaping the heel? (Me neither...)...I kind of use John Maye's router one from the neckmaking video, but still end up doing alot by hand...a maple neck convinced me there must be a better way....
