It is currently Fri Jul 18, 2025 6:50 pm
PostPosted: Sat Jan 08, 2005 6:19 am
Is there any way to fix the run out on a drill press quill. My Delta 350 works fine for bits, but when I chuck up a robo sander or anything like that I get too much wobble.
Thoughts?
PostPosted: Sat Jan 08, 2005 6:39 am
Brock...I have the same drill press. I purchased a drum sanding system from Lee Valley that uses a bearing disc into which the bottom of the drum is captured. http://www.leevalley.com/wood/page.asp?page=20202&category=1 ,42500&ccurrency=2&SID= It rotates without any runout whatsoever. You might use something similar with the Robo-Sander.
