It is currently Fri May 08, 2026 7:02 am
PostPosted: Sat Jan 08, 2005 12:44 pm
There has been some interest in a low cost jig to do this and it doesn't get any cheaper than do-it-yourself. Here is my jig for slotting these headstocks.
Slotted headstock jig
It's not real refined but it works.
PostPosted: Sat Jan 08, 2005 12:50 pm
[QUOTE=John How] There has been some interest in a low cost jig to do this and it doesn't get any cheaper than do-it-yourself. Here is my jig for slotting these headstocks. It's not real refined but it works.[/QUOTE]
John, it looks refined enough for me. This definitely needs to be posted to the jig section. Do you think it would work as well without the pins in the nut position? I was thinking using bolts and wing nuts on the top would probably be secure enough. Thanks for sharing this with us.
PostPosted: Sat Jan 08, 2005 12:54 pm
John, that's a good one. thanks for posting. Paul
PostPosted: Sat Jan 08, 2005 1:49 pm
Verrrrry clever! Thanks for sharing. I need one of these. I've become partial to the 12 fret and really like the slothead. BTW, what are you using to drill the tuner holes?
PostPosted: Sun Jan 09, 2005 7:10 am
Brilliant John...Who needs to spend $249.00? THANKS!
PostPosted: Tue Jan 11, 2005 6:59 am
John, thanks for the look at your jigs. As usual, your work inspires me. A couple of questions if you don't mind:
1)- How wide are you making your slots?
2)- How do you drill the tuner holes?
In my way of doing these, I'm more comfortable predrilling the tuner holes, then cutting away the slot material. But that requires shaping the peghead to final shape before cutting the ramps. Curious about your thoughts on this.
Thanks, Steve
PostPosted: Tue Jan 11, 2005 8:02 am
John this is brilliant.
PostPosted: Tue Jan 11, 2005 8:05 am
HI Steve
My slots are 1/2" so the guide needs to be 1/2"+ the clearance needed for your router base guide. I don't recall which guide I used but I used a 1/4" spiral cut bit. My router is a Porter Cable laminate cutter.
Your right, it would be better to drill the holes before cuting the slots. I wanted a jig that didn't use bulky clamps so I opted to use the slots as locators for the shaping jig. and since the shaping needed to be done before the holes are drilled, this is just the way it went. I plan to (and haven't done so yet) make a jig similar to the one that I have been lusting after (I'll not name the manufacturer). but it is the, "self aligning jig that allows all three holes to be drilled and it is more expensive than a cheapskate like me wants to pay so I don't have one" jig. How's that for a description without saying it.
I may use a spacer or something in the slot to help with wood chipout while drilling if it becomes a problem or I may have to rethink my jig.
JohnJohn How38363.6737037037
PostPosted: Tue Jan 11, 2005 8:11 am
PostPosted: Tue Jan 11, 2005 8:25 am
Non-sense, you are brilliant and the resulting work is beautifully handsome. Beautiful is such a feminine word, but handsome makes a bride blush at the masculinity. Go John!
cron
