It is currently Wed Jun 10, 2026 6:26 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 21, 2008 10:44 am
Mike Kroening wrote:
I got them from Micro Fasteners. I used the 2-56 brass inserts. part #BTI0256
http://www.microfasteners.com/
Upon my reading the fine print of the insert. DOH!!! It says to use the slotted end for thread cutting on hardwood and use a screw and jam nut to screw it in. well, call me Dummy!!! :) Not sure that will help but I will try it!!
Mike, Thanks for that info. bliss
PostPosted: Fri Mar 21, 2008 10:53 am
wyodave wrote:
Hey D L
I addressed the question you had about the Beard neck to body joint to Mike. I meant to answer you. I'm sorry for the screw up.
Hey Dave, I saw your reply Thanx.
PostPosted: Fri Mar 21, 2008 10:50 pm
You are quite welcome I hope it helps.
BTW Still need to drill the hole larger and taper it before screwing in the insert. TEST IT BEFORE USING ON THE REAL THING!!! :)
I'm outside looking in, just farther from the window than most.
PostPosted: Fri Nov 19, 2010 11:06 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Zip/Postal Code: 63017
Mike Kroening,
I am so glad to hear you say that this is your first Resonator and first acoustic. I am building my first acoustic now and want to start building my first resonator. I am going to give it a go now that I see I am not the only one to think that way.
I tried to get on your site but kept tell me it was no longer available. I missed my chance I guess.
Ken
