It is currently Thu May 14, 2026 9:23 pm
 Post subject: Neck bolt pulled out
PostPosted: Wed Mar 20, 2024 7:22 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Would the carpenters toothpick fix be good for this or something better?
Hutch
 Post subject: Re: Neck bolt pulled out
PostPosted: Wed Mar 20, 2024 7:39 am
City: U.P.
I guess we gotta know how it was bolted on first. Was it a hanger bolt, a "furniture" bolt with an insert in the heel, a butt joint, a mortise and tenon, or... --- and how was it installed before it failed? Did it fail just sitting there or was there a fall or could it have been over tightened? Maybe a picture would help you get advice too.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Hesh (Wed Mar 20, 2024 8:30 pm)
PostPosted: Wed Mar 20, 2024 9:14 am
First name: Richard
City: Warwick
State: RI
Hanger bolted butt joint. It was stored in a bad environment and just pulled out from string tension.
Hutch
PostPosted: Wed Mar 20, 2024 10:10 am
City: U.P.
If it were me, I'd consider switching to a threaded insert and furniture bolts. There just isn't a lot of holding power in a hanger bolt thread when it is going into a shallow heel in a butt joint, especially end grain.
How deeply did the screw end of the hanger bolt penetrate the heel?
N8ZED
PostPosted: Wed Mar 20, 2024 1:26 pm
First name: Richard
City: Warwick
State: RI
I'll answer this when I get it on the bench. It'll be a while.
Hutch
PostPosted: Wed Mar 20, 2024 1:47 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
A hanger bolt ought to grip pretty well. I usually use inserts and 1/4-20 bolts, but use hanger bolts when I expect greater stress. The hanger bolt goes deeper than the insert. I always put a 1/2” maple dowel in the heel with its edge a quarter inch back so there’s some cross grain for the insert or the bolt to grab. I don’t trust endgrain. If your hanger bolt had no cross grain to grab, I might consider removing the heel cap, drilling the heel, and installing a dowel. I usually have to turn the dowel down a bit to fit in a 1/2” drilled hole.
PostPosted: Wed Mar 20, 2024 3:01 pm
First name: Richard
City: Warwick
State: RI
I'll keep that in mind, thanks.
Hutch
