It is currently Sun Jun 22, 2025 6:21 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 20, 2007 3:04 am
First name: Nelson
Last Name: Palen
That is too cool, Sheldon!!!!!
PostPosted: Thu Dec 20, 2007 4:45 am
City: Wheatley
Nice jig Sheldon. Any chance of getting some more photo's of it....with a fretboard on it.
Paul
PostPosted: Thu Dec 20, 2007 11:26 am
First name: Nelson
Last Name: Palen
I'm simply in awe of the ingenuity of this fixture and it's multiple uses.   Been trying to think of where I've ever seen the idea of a contoured saw cut using the actual part as the pattern. "Elegantly simple"!
PostPosted: Fri Jan 04, 2008 7:04 pm
Thanks for the props.  Sorry to take so long getting some photos done.
There are a couple of close ups of the spring loaded support pins, cam lock, slotting process and a bad one of the radiusing fixture on an edge sander.
PostPosted: Sat Jan 05, 2008 1:36 am
City: Wheatley
Sheldon, thanks for the photo's. How are you registering this jig to cut the fanned frets?
Paul
PostPosted: Sat Jan 05, 2008 9:59 am
[QUOTE=PaulK]
Paul
Two pins on the table directly inline and under the blade path.  They key into the holes on the front of the neck fixture and slots on the back.  The slots maintain side to side alignment while offering a bit of forgiveness for accuracy.  Laser cut steel is pretty accurate, but it does expand slightly as it heats up when being cut.
 Post subject: Re: Fret slotting
PostPosted: Tue Jan 13, 2009 9:05 am
I use bits ranging from .018 to .023 in a Makita Router at 24000 rmp.
Since I make dulcimers not all my fretboards are ebondy or rosewood. In the softer woods I use the smaller bits.
My bits are from several sources... Enco, MLS, Robbjack...
Feed rate is 9 ipm. and I take two passes to make a slot .070" deep.
I do a radius cut also - like many folks, I "invented" that myself.
I'm using a Shopbot CNC.
Thanks to everyone for all the great tips, info and resources.
David
www.davidbeede.com
