It is currently Mon Jun 16, 2025 7:55 pm
 Post subject: dc servo 4th axis?
PostPosted: Wed Jul 05, 2017 4:11 pm
My machine is dc servo. I can find lots of stepper 4th axis but not much for servo. Anyone have a good inexpensive source?
 Post subject: Re: dc servo 4th axis?
PostPosted: Thu Aug 31, 2017 9:24 am
Does your machine already have a driver for the 4th axis? If not, you could just as easily add a stepper driver instead of a servo drive.
PostPosted: Thu Aug 31, 2017 12:36 pm
My thought is that a stepper driver would be sufficient for a low-motion axis like what is typically used in this application. In fact, the stepper is probably the preferred type of motor with higher torque and good accuracy at these lower speeds. Far less need for an encoder etc. As long as you can reasonably mix the two types in the system, you're probably okay.
