It is currently Mon Apr 27, 2026 8:03 am
PostPosted: Thu Feb 22, 2007 10:27 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
I've had some good success recently using my CNC machine to profile acoustic guitar sides prior to bending. By this I mean that I've used a few CAD tricks in order to get the precise curve that the bottom edge of an acoustic side makes if you straighten it out. I.e, this means that after gluing the end blocks on I will only have to make minimal corrections via sanding in order to prep the sides for gluing the top and back on.
I bent some mahogany sides the other day and it looks like this is going to work very well. Cool stuff - does anyone else have any experience with this?
I've been trying to think about ways to revamp the building process now that I have the CNC...
http://www.PeakeGuitars.com
PostPosted: Thu Feb 22, 2007 10:49 am
I'm SO envious.
Taylor does that with their sides too.
PostPosted: Thu Feb 22, 2007 11:50 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Dang, just when you think you had a new idea!
PostPosted: Thu Feb 22, 2007 11:51 am
Trev...I have not used CAD to precut sides but I did work on a project several years ago where I used 3D modeling and the "sheet metal" functions to design 3D opjects and then "un-wrap" the models into 2 dimensional full scale drawings. I worked very well. I am sure this could be done for what you are talking about. I will try it in Solidworks and see what happens.
Brad
Avon, OH
PostPosted: Thu Feb 22, 2007 1:10 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
I'm doing that exact thing in rhino using the "unroll developable surface" command.
SW is great for mechanical design, but I'm really really enjoying Rhino for the artsy stuff.
PostPosted: Thu Feb 22, 2007 1:41 pm
Actually I used the sheet metal command in Microstation...it was a really difficult 3D package but it worked. I have been playing with Solid Works and can't figure it out...but I will! By the way..have you checked out the Taylor Factory Friday video's? Check out how they side bend with precut sides...cool stuff.
Brad
Avon, OH
PostPosted: Thu Feb 22, 2007 2:07 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
I remember seeing the side bending machine..but I didn't remember seeing that they had done that.
Those factory friday's are great, Taylor must be a cool company to do release something like that. The guitar industry is certainly different from other industry..
PostPosted: Fri Feb 23, 2007 12:21 am
Last Name: Watkins
City: Lake Zurich
State: IL
I've done templates for a number of my customers in the same manner. I've found that the trick to doing it accurately is to provide the bending molds as well. That way you can control the position of the slot at the waist and use it to index the side in the bender.
John Watkins
CNC Guitar Parts
PostPosted: Fri Feb 23, 2007 3:04 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
I've found that if you start bending at the back of the side and work your way up it works pretty well (I'm using a bending iron at the moment). I am using a mold that I CNC cut as well, so I know that my side surface is as accurate as possible.
Fun stuff..
PostPosted: Sat Feb 24, 2007 6:39 am
Last Name: Garrish
I've been wondering about ways to index the sides when the profiles are CNC cut. I was considering using a two-bend system like Taylor does (bend from flat to waisted then use the waist bend to re-index and bend bouts). It's more work, but it seems like it would give more accurate side bends -> less sanding.
Bob Garrish
