It is currently Sun Apr 26, 2026 11:45 pm
PostPosted: Wed Apr 18, 2007 7:16 am
First name: Nelson
Last Name: Palen
Haas
Not sure how new but first time I've seen it. This type of machine bridges the gap between light weight table routers and the Haas/Fadal type vertical machining centers. The 24K rpm spindle would handle a lot of wood machining jobs and the tool changer would be icing on the cake.
I want one! <g) (Don't really need another router)
Nelson
PostPosted: Wed Apr 18, 2007 7:41 am
Last Name: Garrish
Looks like a pretty nice setup, although a look at Haas' site makes me a bit wary. The positional accuracy is +- 5 thou which seems pretty high to me, and they don't mention the repeatability at all. That high-speed spindle seems pretty sweet compared to my 10K, though. I bet it could really rip through production stuff in softer materials.
Bob Garrish
PostPosted: Thu Apr 19, 2007 3:37 am
This is what I did for mine, cost me less than a $600 and works great.
http://www.cnczone.com/forums/showthread.php?t=35094
Steven
PostPosted: Tue Apr 24, 2007 3:45 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
The cnc routers I have seen have pretty good accuracy at low feed rates, but when you ramp them up they start taking shortcuts. I would bet you could run that thing at least a couple hundred IPM before you'd experience too much deterioration. Unless you were doing some serious production, you probably wouldn't need to run faster than that.
That looks like a good deal though...especially for a machine complete with an ATC.
http://www.PeakeGuitars.com
PostPosted: Fri Apr 27, 2007 2:01 am
First name: Nelson
Last Name: Palen
Probably using rack and pinion for the X and Y although some accuracy can be achieved with a preloaded pinion/rack.
