It is currently Thu Jun 26, 2025 7:58 am
 Post subject: Another guitar
PostPosted: Fri Jan 21, 2011 9:44 pm
First name: Jeff
Last Name: Kosmoski
City: Beaverton
State: OR
Here's a look at another guitar I've been working on.
These were taken before paint. I hope to have it painted in a week or two.
This one has two planks of maple in the middle, followed by a plank of walnut on each side, followed by ash.
It's basically wired like a Strat, except that in the middle switch position, instead of getting the middle p-up only, you get the bridge and neck.
Here's a few photos of its precursor.
This one only has 2 p-ups.
I've since softened up some of the curves on the un-painted one.
Anyhow, there ya go.
Any and all comments, critiques and questions greatly appreciated.
Jeff
 Post subject: Re: Another guitar
PostPosted: Fri Jan 21, 2011 10:23 pm
First name: Nelson
Last Name: Palen
Awesome work, Jeff!
Do you finish the contours by hand?
Nelson
PostPosted: Sat Jan 22, 2011 12:14 am
First name: Jeff
Last Name: Kosmoski
City: Beaverton
State: OR
npalen wrote:
Awesome work, Jeff!
Nelson
Nelson,
Thanks for the comments!
Regarding the finish: I need to sand them afterwards, if that's what you mean. However, the CNC gets them pretty close to where they need to be.
I'm still experimenting with stepover distance; but I get pretty good results with a .05" stepover, using a .50" ball end mill.
Jeff
PostPosted: Sat Jan 22, 2011 8:42 pm
I like this one even better. How do you fixture and reference the body to work on the back?
PostPosted: Sat Jan 22, 2011 10:17 pm
First name: Jeff
Last Name: Kosmoski
City: Beaverton
State: OR
I machine "tooling holes" into the front of the guitar body, either in the bottom of the p-up pockets, on the neck, or at the bridge. I then generate some mounting blocks, and press a .25" dia dowel pin through them. I use the dowels to locate and zero, and clamp the "sandwich" together with long woodscrews.
Hope this helps.
Jeff
PostPosted: Sun Jan 23, 2011 8:52 pm
Screws up from the bottom - brilliant!
PostPosted: Sun Jan 23, 2011 9:29 pm
Last Name: Garrish
Jeffkos wrote:
Nelson,
Jeff
Unique design, and good ideas on the fixturing. If you're not in a hurry to pump them out, then love thy self and get a 3/4" ball and drop down the stepover until you can get away with just rubbing off the tooling marks, though.
It might make me the laziest man alive, but if it's a personal project then I'd much rather have the Fadal run for an extra hour rather than do an extra 20 minutes of sanding :)
Bob Garrish
