Joined: Tue Feb 05, 2008 10:08 pm Posts: 224 Location: New York
Please excuse the post, as it has nothing to do with guitars, but I thought some of you might find this interesting...
I just cut a new QuadCopter frame on my cnc machine, out of g10, or garolite. I used a 1/16 inch mill, and I was really impressed with the results (designed in Solidworks, offcourse).
You can watch the video below to see how it flies, and also, look at the night flight stunts at the end. Controller is an arduino board, with another board that has about 10 sensors on it, like accelerometers, gyros, compass, GPS, barometer, and a sonar sensor for altitude hold...basically, this thing can be considered a "drone" since it does have autonomous way point capabilities, which will be the next set of tests....
Very cool. Fit with a camera and you'll have a lot of fun!
_________________ "Act your age, not your shoe size" - Prince
Thanks Guys...
I am using 2217's/1050KV from Hobbyking....they are swinging relatively large props at 12x3.8 (two tractors and two pushers...).
I get about 7 minute flights on a 3000mAh lipo.....not doing any aggressive maneuvers obviously...
I think I can easily lift a small SLR, and I am in the process of creating a camera mount/pod that will fit under the quad for that purpose...again, garolite....
The board also has the ability to integrate camera stabilization servo's, so we will also see how that goes....need to get a bit more comfortable with flying it first, and ring out all the kinks....
Joined: Mon Dec 27, 2004 11:25 pm Posts: 7207 Location: United States
That's way too cool.
_________________ "I want to know what kind of pickups Vince Gill uses in his Tele, because if I had those, as good of a player as I am, I'm sure I could make it sound like that. Only badly."
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
