It is currently Sat Apr 25, 2026 7:58 am
PostPosted: Mon Apr 04, 2011 7:42 am
Please excuse the post, as it has nothing to do with guitars, but I thought some of you might find this interesting...
I just cut a new QuadCopter frame on my cnc machine, out of g10, or garolite. I used a 1/16 inch mill, and I was really impressed with the results (designed in Solidworks, offcourse).
You can watch the video below to see how it flies, and also, look at the night flight stunts at the end. Controller is an arduino board, with another board that has about 10 sensors on it, like accelerometers, gyros, compass, GPS, barometer, and a sonar sensor for altitude hold...basically, this thing can be considered a "drone" since it does have autonomous way point capabilities, which will be the next set of tests....
:geek:
-CyborgCNC
http://www.cncguitar.com
https://www.facebook.com/CncGuitar
PostPosted: Mon Apr 04, 2011 9:04 am
Very cool.
Fit with a camera and you'll have a lot of fun!
PostPosted: Mon Apr 04, 2011 9:17 am
Won't be long and there will be UFO sitings all over your area. wow7-eyes
Very Cool though, What size Out Runners are you using?
I'm outside looking in, just farther from the window than most.
PostPosted: Mon Apr 04, 2011 9:39 am
Thanks Guys...
I am using 2217's/1050KV from Hobbyking....they are swinging relatively large props at 12x3.8 (two tractors and two pushers...).
I get about 7 minute flights on a 3000mAh lipo.....not doing any aggressive maneuvers obviously...
I think I can easily lift a small SLR, and I am in the process of creating a camera mount/pod that will fit under the quad for that purpose...again, garolite....
The board also has the ability to integrate camera stabilization servo's, so we will also see how that goes....need to get a bit more comfortable with flying it first, and ring out all the kinks....
-CyborgCNC
PostPosted: Mon Apr 04, 2011 2:38 pm
Very cool. I was wondering whether you were using counter rotation or not, you answered that with the use of the pusher props. :)
Neat project.
PostPosted: Tue May 10, 2011 11:47 am
That's way too cool.
