It is currently Tue Aug 05, 2025 2:19 am
PostPosted: Mon Mar 04, 2013 2:35 pm
First name: Jeff
Last Name: Kerr
City: Bellingham
State: Washington
Zip/Postal Code: 98229
For anyone with a hobby CNC router or milling machine, I've written a simple (& free) Windows program to generate G-codes for cutting blind fret slots using a tiny (something like 0.022" dia) end-mill. You enter in the scale length, nut width, etc. and it generates the G-code paths. If your CNC machine is not long enough to do the fret board in a single setup, it generates the proper code for you to re-position the fret board and continue cutting slots.
It generates paths for straight or fan-fret fret patterns. It also handles compound radius fret boards. You start with a pre-radiused fretboard, and each slot is cut to match the radius.
You can download the program from lobocnc.com/userapps.html. This program is part of an open-source CNC milling machine project I am starting, for anyone interested in getting into CNC. You can see a video of cutting fret slots at lobocnc.com/gallery.html.
PostPosted: Mon Mar 04, 2013 3:02 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Hey Jeff! Glad to see you made your way over here. I know you will fit right in with the CNC crowd. Welcome to the forum :)
